BRAKE FLUSH was advice by dealer?need info
Old Nov 9, 2010 | 03:25 PM
IVANISINLA's Avatar
hi name is ivan infinity dealership recommended me to do a breakflush i dont know that much about cars but just the basic so i never heard of that before. This my first g35 and i never heard of brake flush one person recommended me not to do it but just to change oil only and dont clean the inside with any liquids. need some advice please here is some info coupe with 47,888 miles
Old Nov 9, 2010 | 03:28 PM
Project's Avatar
Usually you do it when your changing out your pads and rotors. If your really set to do it yourself you can follow just about any google search.
Old Nov 9, 2010 | 03:31 PM
Jeff92se's Avatar
Red Card Crew
Um, if you have gone 47,000 miles w/o a brake fluid flush, do it. By the dealer or other mechanic.
Old Nov 15, 2010 | 04:13 AM
IVANISINLA's Avatar
I changed brakes that's about it but never the brake flush
Old Nov 16, 2010 | 04:06 PM
msommers's Avatar
Probably should do a clutch fluid change as well if you have a manual.
Old Aug 15, 2012 | 04:13 PM
dragonv's Avatar
I'm at 120K and just changed my brakes, should I do a brake flush or just continue to top it off when the brake light comes on?
Old Aug 15, 2012 | 04:54 PM
thescreensavers's Avatar
Mr.202?
Brake fluid should be flushed at least every 3 years. Brake Fluid is Hydroscopic so it will absorb moister thus lowering your boil points, if this goes for too long and too much water is absorbed it can start to rust the system. The ABS system is not cheap.
You can DIY this by buying a bleeder(Motive Brake bleeder) for 50 bucks and fluid at Advance (Valvoline Synthetic DOT3/4) for like 8 bucks for 32OZ you need about 1.5 quarts, I do 2 quarts since once you open the containers you cant really seal them well enough.
You will need to jack your car up and have some vinyl tubing(homedepot) and a bottle (empty 2 liter)
Old Aug 16, 2012 | 04:11 PM
brandon1978's Avatar
If your brake fluid has to be topped off, you should find the leak. It may not be a big deal, but the system should never require topping off. For me, brakes are too important to not be working 100%. I recommend at least having a trusted mechanic take a look.
Like mentioned above, a brake flush should be done at least every three years.
Frankieg35
Mar 20, 2016 09:42 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
miata007
Aug 17, 2015 04:36 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
