Tanabe pro s-oc coilovers G35
Ok so i have the Tanabe coilovers and it is running the pro210 springs. My settings are maxed out both front and the rear.
Does anyone know if i sawp them with the df210 springs will it lower my ride and does anyone know the actually height number difference...
Ive looked and cant find a straight answer nowhere.....
Damn that's maxed out??? That doesn't even look as low as the lowest springs available.. Not familiar with this particular coilover, but if it is oem style, you sure you didn't install it leaving the springmount in? Also you could explore popping a collar to get it lower.
I think i might have to do the collar trick for the rear...
Something doesn't seem right. The Pro S-OC lists their drop at 2 3/4"F and 2 3/8"R and you're not dropped that much. I'm riding on the Pro 5 which only lists a drop of 1 1/2" all around and I'm lower than that with 1 collar removed both F&R.
You should be able to get lower in the back.
maybe our spring rates are different resulting in the height difference?
I took out the helper spring up front and left the locking collars but the rear i took our both collars. Im thinking I should have gone with stance gr+ from the get go.
I'm assuming the "locking collars" are the two pieces used to adjust the height?
I have the PRO-5's and am looking for ways to lower the rear a little more.
I'm speaking from a sedan perspective, but the results on your coupe should be similar.
