ATTN: BC Racing coil over owners
Old Nov 18, 2010 | 08:41 PM
caketech's Avatar
hey guys, i just got the BC coils and among a few things i came into an issue
what should i set my dampers at? i want it a bit stiffer than stock, but not by much
what'd you guys set it at? i have a coupe if that makes a difference.
Old Nov 18, 2010 | 09:48 PM
Xet's Avatar
Xet
Pretty much everyone will tell you to start at the middle and then change it as you drive around. Everyone has different tolerances of what is too stiff and how much increased handling they want. Plus everyone's driving environment is different, if you have a crap ton of pot holes you are probably not going to end up as stiff as someone in a nice area. It is adjustable for a reason, to suit the needs and environment of the user.
Old Nov 19, 2010 | 12:05 AM
caketech's Avatar
problem, is i don't want to udrill holes for the extensions, i just wanna set it and forget it.
Old Nov 19, 2010 | 12:17 AM
Snakes' G's Avatar
I didn't have to drill holes in my 03 coupe. I doubt you would have to in an 04.
Old Nov 19, 2010 | 04:17 AM
caketech's Avatar
for the extensions? did you snake it into the interior some how?
Old Nov 19, 2010 | 10:38 AM
eurodre's Avatar
oh boy yet once again another incredibly subjective question
well lets see here do you have wheels that are close to the fender? if yes then set to stiffest if no then something less than full stiff
and you don't have to drill holes for the extensions there are plenty already there in the wheel well
Old Nov 19, 2010 | 11:17 AM
Snakes' G's Avatar
Just take off the plastic clips for the baby seats and remove the metal anchors inside. It would be easiest for one person to hold some insulation out of the way while u snake it through. I took off the ***** on the top of the extenders while I did it. Sorry if that didn't make much sense.
Old Nov 19, 2010 | 01:17 PM
bjquinnIUmed's Avatar
12 clicks from full firm works just right for me!
Old Nov 19, 2010 | 01:23 PM
Terribleone's Avatar
I can really tell you what to set them at i have mine extremely stiff (i think only a couple off of full firm but i cant remember the exact number), but i will say i see you live in BC with winter coming when the coil overs get cold they get very very very stiff i have to drop mine down quite a bit when the weather gets very cold.
Old Nov 20, 2010 | 01:03 AM
caketech's Avatar
did it work for both sides?
Old Nov 20, 2010 | 11:36 AM
Snakes' G's Avatar
Yes they are exactly the same.
infinitiway
Aug 8, 2017 12:38 PM
Vqalexisz
Oct 14, 2015 12:48 AM
joeslates
Sep 11, 2015 11:19 PM
kevintandmd
Sep 3, 2015 06:41 PM
