Does G37 SPC camber kit fit the G35 with RAS
Old Dec 7, 2010 | 11:20 PM
jnguyen37's Avatar
I was wondering if the G37 SPC camber kit fit on the G35 with rear active steering? I got a good deal on G37 SPC kit(free) but I dont think it fits.
Old Dec 8, 2010 | 01:09 AM
datbeans's Avatar
I'm 99% sure they dont...
Old Dec 8, 2010 | 01:10 AM
Frankieg35's Avatar
Yeah doubt it!!
Old Dec 8, 2010 | 01:43 AM
jnguyen37's Avatar
thanks for the info
Old Dec 8, 2010 | 02:42 AM
The Stimulation's Avatar
Front or rear camber kit? If it's the rear, it should work. I believe a local shop used Battle Version Camber arms from a G35/350Z on a a 370Z. Being that the 370Z and G37 are the same, then it should work. I can't confirm 100% though. Fronts, I'm not too sure about, but I don't think they are interchangeable.
Old Dec 8, 2010 | 10:00 AM
bluedevils95's Avatar
i thought it would work because i thought the only thing they change was the engine?
Old Dec 8, 2010 | 10:42 AM
gtoor1990's Avatar
I dont think it will work either...
Old Dec 8, 2010 | 11:24 AM
jnguyen37's Avatar
I check it out and the part number is the same so I think it will work. its free so Im take it and testfit it
The front are interchangeable Levon. The G37 actually uses the G35 front SPC camber arm
Old Dec 8, 2010 | 12:48 PM
Really? Didn't know that. That's good to know then. Since I don't have a G37 would you be my counterpart and run -5 front camber and -6 rear camber (keep it somewhat even) and throw on some 10's with double digit negative offsets in front and 11's with double digit negatives in the rear?
Old Dec 9, 2010 | 12:25 PM
datbeans's Avatar
surprised me. Didn't know they were interchangeable good info
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
nascarbuff17
Jul 16, 2015 10:23 AM
LoSt180
Jul 15, 2015 08:31 AM
