Advice on replacing Shocks and Struts
Old Dec 9, 2010 | 04:18 PM
spacecitygroove's Avatar
Sorry for making a thread back to back.
Do our cars have STRUTS in the FRONT, and SHOCKS in the REAR?
My car rides like CRAP!
Everytime i hit a bump the entire car rattles! It doesnt ride like it should
Old Dec 9, 2010 | 04:33 PM
Irrelevant's Avatar
I'd wait until you swap out your wheels/tires. You probably have 30 or 35 series tires on those 20" wheels.
If you go to 18" wheels as you wrote, you can run 40 or 50 series tires, which will improve ride quality - though you may or may not give up some cornering performance at the ragged edge of the car's ability.
I think the factory 17"'s that came on my coupe were 50 series. I have 35 series on my aftermarket 19"'s, and 55 series snow tires mounted on my factory 17" wheels. When I swap wheels from the 19's to the 17's it's almost like the difference between driving a dump truck vs. a Cadillac. That's an exagerration, but it is a noticeable difference.
Old Dec 9, 2010 | 04:34 PM
brandon1978's Avatar
That's correct. Front struts and rear shocks.
As for the ride and assuming you are stock, your dampeners (struts/shocks) are probably worn out. That doesn't hurt anything, it just makes for a bad ride and the handling won't be what it once was. Different tires have different levels of firmness as well, and shorter sidewalls will have a stiffer ride. The solution is to get new dampeners. Tokico (same company that makes our OEM dampeners) has HP non-adjustable (~$300) and D-spec adjustable (~$525). Both are highly rated. Going to coil-overs is also an option.
Old Dec 9, 2010 | 06:04 PM
superchargedg's Avatar
Since you like to start multiple threads on the same thing it your 20" rims that are killing your ride....and please get rid of those hideous wheels.
Old Dec 9, 2010 | 09:28 PM
i already got rid of them, thank you superchargedG.
car rides well, please see other thread. but still rattles like hell and bouncy
Old Dec 9, 2010 | 10:11 PM
gtoor1990's Avatar
^^^ hmmm.... Interesting... (the rattling)
Old Dec 10, 2010 | 08:11 AM
spoolinupblue's Avatar
I replaced my shocks and struts with the Tokico Blues...they are great. Then I lowered it on Tanabe springs.
Old Dec 10, 2010 | 08:42 AM
petesg35's Avatar
Spoolinupblue which tanaba springs do you have?
Old Dec 10, 2010 | 09:00 AM
I bought the NF120 (1" F & .6" R)
Old Dec 15, 2010 | 10:24 AM
prell's Avatar
dayum, that looks sweet, perfect wheel gap !
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
cyrus32
Jul 18, 2015 06:22 PM
