where can i get a new hub
Old Dec 19, 2010 | 05:58 PM
kennymo's Avatar
anyone know of a store that i can get a new wheel bearing and hub from? i dont want to get it from the dealer if i dont have too.
also. do you think extended studs would void my warranty on the hub/bearing?
Old Dec 19, 2010 | 06:54 PM
Frankieg35's Avatar
With dealerships u never know about what they will void and what they wont when it comes to aftermarket stuff.. Check ebay for hub and bearing..
Old Dec 19, 2010 | 08:24 PM
G35Papa's Avatar
Check with one of the guys at riversideinfiniti
You can also check here
http://infinitipartsonline.com/
Front or rear bearing/hub Kenny? I don't think studs themselves would void a warranty Kenny. I just wouldn't mention running spacers
Old Dec 19, 2010 | 09:24 PM
kennymo's Avatar
its the rear. yea im not going to mention spacers. i guess ill try it
Old Dec 19, 2010 | 09:25 PM
kennymo's Avatar
i do think they will try and say its because of the rims though
Old Dec 19, 2010 | 09:58 PM
Project's Avatar
Rear has to be pressed in. I think its the cheaper of the two. I got mine at a nissan dealership it was like 30 bux cheaper.
Old Dec 19, 2010 | 10:04 PM
kennymo's Avatar
well im hoping the dealer will fix it under waranty and give me a rental also because i still have to go to work tomorrow
Old Dec 19, 2010 | 10:05 PM
Project's Avatar
Anything is worth a try. If not it takes less then an hour to do once the hub is off you will need to take it and have it pressed on. Good luck.
Old Dec 22, 2010 | 11:01 PM
Gdirtyfiver's Avatar
Is there such thing as a "wheel hub assembly" for the front 05 g35x that comes with bearings and hubs together in one piece/pressed. I found TIMKEN has a wheel hub assembly at parts geek.
http://www.partsgeek.com/catalog/200..._assembly.html
I'm a bit skeptical because as far as I know its suppose to be 2 separate pieces.( hub and bearing). Can anyone confirm this?
Old Dec 23, 2010 | 01:39 AM
G35Papa's Avatar
On the G35 the front is one piece (sealed bearing inside the hub). I can't confirm this on the X though.
Old Jan 3, 2011 | 02:13 PM
spinn's Avatar
Bought one for my front pass side from Rockauto for about $120 shipped. The bearing is already pressed onto the hub; bearing isn't typically sold separately, but you could theoretically source the bearing and press it on yourself...but that'd be too much trouble.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
NJ6MT
Sep 10, 2015 08:40 AM
