SPC front camber arms
Old Jan 20, 2011 | 06:17 PM
05skyline's Avatar
I installed a set of spc front arms only without shim kit and from comparison to what it was before, it doesnt look like it gave much more positive camber over oem. Thats after having the camber bolt pushed and tighten all the way out as far as it will go within the slot towards the fender on both sides.
Old Jan 20, 2011 | 09:47 PM
fatlip's Avatar
Heres another question. If u dont use the shim kit will u have problems with the VDC ABS???
Old Jan 20, 2011 | 09:48 PM
JBF's Avatar
JBF
why would you not add the shims? they give you 2 degrees positive camber
Old Jan 20, 2011 | 09:51 PM
fatlip's Avatar
I saw on a few forum post that some guys didnt use the shims. Im not that low and my alignment was able to be brought back to spec.
Old Jan 20, 2011 | 09:55 PM
G35Buzz's Avatar
Some is better than none... a lot of other camber kits offer positive camber and deliver none..if you need more that is what the shims are for...
I made a rhyme spc should pay me>>> look another rhyme im on a role
Old Jan 22, 2011 | 12:05 AM
05skyline's Avatar
yea im gonna take my G in for another alignment to see how much negative camber is still there....hopefully i can be near only -0.5 now from -1.8 with just arms installed. If not i guess i will have to buy set of spc shims then.
Old Jan 22, 2011 | 01:37 AM
Frankieg35's Avatar
I have a set of Spc shims if u need them.. pm me if u do..
Old Jan 22, 2011 | 02:12 AM
05skyline's Avatar
pm'd
Old Jan 22, 2011 | 03:49 AM
AARONHL's Avatar
Put the shims in! You'll have more adjustment when using the negative camber of the arms.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
cbax
Aug 17, 2015 07:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
