JIC magic ****ed me up
Old Feb 9, 2011 | 01:05 AM
kenslen's Avatar
i purchased jic magic FLT A2 and i try to max it out by take off the adjustment rings from the rear and everything but it didnt get low enough. i dont really know what to do now...i wonder what spring will give the lowest drop out there maybe i can buy them and replace them with those ****ty JIc srpings?????
Old Feb 9, 2011 | 01:38 AM
4DGS's Avatar
This is OEM style rear?
There is a quite a few guys running JICs and are dirty low...
Old Feb 9, 2011 | 01:42 AM
kenslen's Avatar
yes OEM rear
Old Feb 9, 2011 | 01:43 AM
kennymo's Avatar
are you sure you have them installed right? posting picture sure would help us
Old Feb 9, 2011 | 01:49 AM
kenslen's Avatar
Uploaded with ImageShack.us
this is how it sits wit negative -5.4 camber before alignment but after the alignment i got -3 so it went higher then this little bit more
P.S rear adjustment rings is off the springs ALREADY
Old Feb 9, 2011 | 01:50 AM
kenslen's Avatar
are you sure you have them installed right? Posting picture sure would help us
i will take it put and take some picture to show ...hopefully ya can help me out thanks a lot
Old Feb 9, 2011 | 01:51 AM
kennymo's Avatar
do you happen to have pictures of the coils actually installed?
Old Feb 9, 2011 | 01:52 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Pick up some Stance GR+ or F&F's if you want maximum ride height adjustment.
4DGS's Avatar
And you removed both collars and they didn't go low enough?
I just looked on the site and there are different part numbers for coupes, sedans and Zs...
What do you have?
Old Feb 9, 2011 | 01:55 AM
kenslen's Avatar
https://g35driver.com/forums/v36-diy...r-install.html
i followed this and i think i installed right just the stupid JIC
kenslen's Avatar
Originally Posted by 4dgs
and you removed both collars and they didn't go low enough?
I just looked on the site and there are different part numbers for coupes, sedans and zs...
What do you have?
jic flt a2
Old Feb 9, 2011 | 01:59 AM
kenslen's Avatar
What do you have?
i took off the adjustment rings only, there is another ring that the springs can sit on if i take it off the springs will move around
Old Feb 9, 2011 | 02:06 AM
by15vc's Avatar
In those pics is the ground level? From what I can see, the ride height is all messed up. Your left front is higher than your left rear and it looks like your right front is lower than your right rear.
Old Feb 9, 2011 | 02:08 AM
kenslen's Avatar
yeah it was before the alignment but now i have everything straight up
Old Feb 10, 2011 | 01:16 PM
kenslen's Avatar
so you guys think shorter springs will help?
big_h
Canada
Apr 1, 2004 02:25 PM
JustinP10
Jan 3, 2004 03:56 PM
Jedi
Sep 15, 2003 11:11 AM
GIlovemycar
May 6, 2003 08:34 PM
