Springs for a Sedan with standard suspension
Old Mar 3, 2011 | 11:04 PM
ryanm8's Avatar
So I have a standard suspension (non-sport)... I wanna drop my car by about an inch so I was looking into 350z springs, but read it's not a good idea to get them with a standard suspension.
Do I have any choices for springs with a standard suspension or should i just go with an 04.5+ 350z complete suspension?
Old Mar 3, 2011 | 11:06 PM
G35SedanGrn's Avatar
also interested, im planning on just going revised350z springs on stock shocks and struts.
Old Mar 3, 2011 | 11:08 PM
thescreensavers's Avatar
Mr.202?
I believe the general consensus is that you can drop on then, but your shocks will die quicker.
Old Mar 3, 2011 | 11:26 PM
LuXXXz's Avatar
you should just get struts/spring combo mounted together just plug and play from a low mileage 350z and it will be easier to put on will last longer and its going to cost probably 100 bucks more all around total which isnt alot if youre going all around
Old Mar 3, 2011 | 11:31 PM
4D05G35's Avatar
+1. The higher spring rate will put more strain on the shocks, but you will be ok for a while.
Old Mar 4, 2011 | 10:46 AM
Abax84's Avatar
Ive had Eibach Pro springs on my stock shocks and struts for over a year, the shocks/struts will need replacing soon (Im at 78k), but I've had no problems at all. Prob not the most efficient setup but I have no complaints.
Old Mar 4, 2011 | 12:55 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by ryanm8
I should just go with an 04.5+ 350z complete suspension.
Fixed
Old Mar 4, 2011 | 03:40 PM
RADIOGUY21's Avatar
Find a complete used Z suspension with low mileage shocks/struts and springs. You can find them cheap on here or the Z forums. I suggest 04.5+ too because its revised rear springs are stiffer in the back and dont suffer from bouncing like the unrevised ones did.
Old Mar 4, 2011 | 04:39 PM
ryanm8's Avatar
For the Z suspension, do you just need the shocks/struts/springs or do you need the additional items as well (A-arms, toe arms, etc.)?
Old Mar 4, 2011 | 05:31 PM
NFSP G35's Avatar
? = 2B || !2B
^No, just the shocks/struts/springs
Old Mar 4, 2011 | 06:10 PM
Nyteowl's Avatar
if you are willing to wait...i'll be selling my tokico hp shocks and stech sedan springs in about a month..The drop is very conservative, about a 2 finger gap..
Old Mar 4, 2011 | 08:34 PM
ryanm8's Avatar
Does anyone know if the 07-08 350z suspension work on the G35 sedan as well? Everything I've been reading is about the 03-06...I have an 08 suspension I can pick up right now local.
Old Mar 5, 2011 | 11:32 PM
ryanm8's Avatar
Well, I just picked up a complete 08 350z suspension
So let's hope there are no fitment issues, lol.
Old Mar 5, 2011 | 11:34 PM
post b4 and after pics plz!!!
Old Mar 6, 2011 | 12:28 AM
kailep's Avatar
I believe 08 350Z springs/shocks are still the revised one since 04.5+. I have the 05 revised springs/shocks and the drop is perfect. 1 in drop all around.
