Questions about Air Ride suspension ask here
Rating: Thread Rating: 3 votes, 4.33 average.
Old Dec 23, 2014 | 12:55 PM
  #481
g35loving's Avatar
Got a little question if anyone can help. Currently on air and running cut front struts with uas bags and uas rear bag in the spring bucket. Looking at going coilover bag with the new Raceland coilovers they just released. I am pretty positive the front will work fine but has anyone tried putting a uas back on a coilover on the rear?
Old Dec 23, 2014 | 01:23 PM
  #482
Hogbone's Avatar
I would call and ask the people at uas
Old Dec 24, 2014 | 09:15 PM
  #483
ChrisKG35's Avatar
I don't believe there is any room for that with UAS bags, maybe if you got the sleeve style bags that are very skinny and combined with the struts already... I believe airlift makes them? But you want to do bag over coil... I am currently running bag over cool with BC extremes and I can't see that working without the bag rubbing and leading to a tear
Old Jan 8, 2015 | 12:52 PM
  #484
Bugeye_wrx's Avatar
stupid question probably, just got the bag riders uas kit for bc br type coils, old style , also with autopilot v2 management. Just wondering if it came with something to wire in the relay for the compressor , and what you ran the "turn on" power off of, i.e.. fuel pump, ecu . Any help would be appreciated .
Old Jan 8, 2015 | 02:19 PM
  #485
Hogbone's Avatar
I used the Signal wire that tells the Bose amp to "power on". And if you bought and Compressor kit it should have the necessary wiring for the relays
Old Feb 19, 2015 | 03:28 AM
  #486
rdavis's Avatar
http://bagriders.com/modlab/products/INFINITI-G35-AIR-RIDE-KIT-WITH-AUTOPILOT-V2-MANAGEMENT.html
WHT do you think of this kit
Old Mar 3, 2015 | 06:20 PM
  #487
cream's Avatar
I'm putting on the airtekk suspension ATM and just have a couple questions.
1. For the rear bags do you remove both the top rubber shock cone and the bottom one or do you still use the bottom one?
2. The suspension comes with two clamps for the speed sensor lines. The round one clamps around the strut but the other one (which is just an extension arm) I am not sure where it bolts on to. Also the brake line I am not sure where to re attach. I have tried searching where people have mounted them and have not had much luck.
Thanks for any help!
Old Mar 20, 2015 | 08:14 PM
  #488
Frankieg35's Avatar
Can I mount an air tank upside down under my rear deck?? I took my 6x9s out when I did my system.. I want max trunk space and was thinking I could run a bracket up through the old holes to secure the tank..
Old Mar 21, 2015 | 01:02 AM
  #489
Hogbone's Avatar
^yes
Old Mar 21, 2015 | 02:12 AM
  #490
bigc's Avatar
Wings Nation
Can I mount an air tank upside down under my rear deck??...
Yes, although I've only seen it done one other time. Search for pix posted by / about 'waijai' (dude named Will from dallas):
https://g35driver.com/forums/picture...unk-setup.html
Old Apr 15, 2015 | 10:29 PM
  #491
StuttersC's Avatar
Can the links be updated on the first page, please? Each one I clicked on went to the site, but not the product.
Thanks.
Old Apr 24, 2015 | 12:39 PM
  #492
b-dRizZy's Avatar
Yes can this be updated plz..
Iam about to install a UAS bag kit on my second gen sedan and idk where to get the power from which fuse to use from the fuse box and need help connecting the compressors
Old Apr 24, 2015 | 01:59 PM
  #493
cturnbull802's Avatar
did someone post these?
if not, it looks like a good option.
http://bagriders.com/modlab/products...-REAR-KIT.html
Old May 18, 2015 | 01:54 PM
  #494
b-dRizZy's Avatar
Does any one know how I can run the power for this ?
IM currently installing my setup but not getting power for compressors to start up..
Valves click but no power on
Running a Stinger relay already
Old May 18, 2015 | 02:09 PM
  #495
VenomGT9's Avatar
I have a buddy selling his system as he's going back to stock. Complete kit with tanks, coils, camber arms...etc
If anyone here in interested, let me know.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
