Pirates coilovers
Old Aug 25, 2011 | 09:03 PM
  #331
lox1985's Avatar
no new developments. Just a picture.
Old Aug 25, 2011 | 09:10 PM
  #332
G35Buzz's Avatar
All I have to say this is a real... 4DSS
Old Aug 25, 2011 | 09:57 PM
  #333
lox1985's Avatar
So does that mean BS or Bad ***?
Old Aug 29, 2011 | 05:18 AM
  #334
VincenzG35's Avatar
how are the pirate holdin up
Old Aug 29, 2011 | 12:57 PM
  #335
G35Buzz's Avatar
4 door sports sedan!!!!
It's Nissan history... Look it up "maxima 4dss" and the G35 sort of took the title away when it came out (unofficially)
Old Aug 29, 2011 | 05:45 PM
  #336
Illuminati's Avatar
Holding up perfect after about 3G miles
Old Aug 29, 2011 | 05:49 PM
  #337
VincenzG35's Avatar
Awesome cause I need to replace shocks struts and springs so I might as well is there a link within the thread
Old Aug 29, 2011 | 06:46 PM
  #338
Illuminati's Avatar
http://item.mobileweb.ebay.com/viewi...id=95393640502
Old Aug 29, 2011 | 06:53 PM
  #339
JaE35's Avatar
Moderator
G35 Sedan
non mobile link http://cgi.ebay.com/ebaymotors/Nissa...item19c54633ea
Old Aug 30, 2011 | 09:18 AM
  #340
toro12's Avatar
20 Year Member
"Pirates coilover" update on the 03 "baby" sedan (44K).
Now with 2600 miles and 6 months on the 43,873 miles 03 sedan I've not had to maintain anything on them. The 25 1/2" fender height holds steady the past 2 months.
Installed mine in Mar'11. Measured my fender lip height and took pic's before and after (see pirates report OP).
It took 1 install; at fronts; and 2; in rears; the first day to land the drop where I wanted it.
That dropped height was 26" front and 26 1/2" rears with 17" standard profile sport wheels.
By June11 with 200 miles plus a change to low profile 19" wheels the settled fender height changed again to 25 1/2" at all corners. (nice, aggressive for nismo front bumper, clean, as low as I want it for DD).
For those of you learning low riding like me please take note here: That 25 1/2" fender height becomes 4 3/4" clear under the rocker panels where DD parking deck ramp fits are starting to sqeeze without any passengers in the car! Also some steep speed bumps get buffed out.
The dampening stiffness remains 75% hard F and 67% hard R. OEM rears.
I've no issues with performance. Level cornering at moderate hard leaning speed, great rebound from bumps of all speeds and during hard leaning corning. Sport handling and sport sedan looks.
The only noise I have to report is the rear shock piston rod slide (oil/gas woosh) can be heard on occasion depending on road and driving conditions. In my exprience that woosh sound is heard in many new shock installs and new cars, so I suppose it it normal for "new" shocks.
The overall suspension mods and especially the coilovers have not produced mechanical knocks, creaks or disappointing/suspicious suspension noises for me to troubleshoot. The bushings are very young on this sedan, some others on the forum reporting suspicious mechanical noises possibly could have the worn out bushings contributing the to dropped coilover mod.
I will re-torque all coilover fasteners as preventive maintainence in the next weeks.
I like these cheapies, a lot. The offer a great value for the DIY builder and low cost training in suspension mods.
Old Aug 30, 2011 | 12:53 PM
  #341
sTeadFasT96's Avatar
Toro, here's a picture courtesy of one of our lovely ladies at the VQFrenzy meet.
Old Sep 2, 2011 | 08:39 AM
  #342
lox1985's Avatar
so, update:
I tried going the route of inserting some gasket material between the car body and the upper mount. Also, due to my spring sitting really close to the nut on the mount (Seems like i am the only one with that spring/nut issue) I decided to put some gasket material in between spring and nut to avoid any metal on metal grinding.
Unfortunately, that did not solve the problem. The noise is still there. It is coming from the right rear as I had a person in the back sit listening to where it is coming from...
Next step would be swap shocks from right to left and vice versa. This will help me eliminate/prove that it could be the issue with shock. Updates will follow.
Other than the noise, everything is solid. Drives great. I need to roll another 0.5 inch on my left fender because it is causing some rubbing on hard cornering.
Old Sep 3, 2011 | 08:47 PM
  #343
Illuminati's Avatar
Do we have any idea on warranty or who can service these coils?
Old Sep 4, 2011 | 11:36 AM
  #344
twalls's Avatar
CLUB MODERATOR
If you bought your coils from Topspeed, then they warranty their product for life.. If you bought them from EBAY or someone else, then I think you're out of luck..
Old Sep 4, 2011 | 11:46 AM
  #345
VictoriousG's Avatar
Hey op can you test out the ebay Turbo now?
