Pirates coilovers
Old Apr 9, 2012 | 12:33 AM
  #481
NFSP G35's Avatar
? = 2B || !2B
^I haz them nao. They came back in stock and I was at the top of the list
Old Apr 9, 2012 | 02:57 AM
  #482
TGMcCoy's Avatar
Originally Posted by Algy
Yeah I was just there this Friday at Topspeed. They just got a 25 amount shipment in and they are already on back order for like 80+ people waiting.
Any how, I got a set of MDU coils for sell. Its the orange ones with the 10k front & 7k rear springs.
Only used them less than 5,000 miles. I got replacement MDU rear shocks which are new and never used. LMK if you want to grab your hands on them. Im located in Dallas TX.
How did your rears fail? Bottom out, sounds etc? Thanks
Old Apr 29, 2012 | 07:56 PM
  #483
SuperTrooper699's Avatar
i got a question, if i bought coil overs, i would only need a rear camber and toe kit right?
Old Apr 29, 2012 | 08:05 PM
  #484
Illuminati's Avatar
Yes but depending on how low you are going and cant get the front camber in spec you would need a front camber kit aswell. But a rear is a must and an alignment after everything is settled.
Old Apr 29, 2012 | 08:27 PM
  #485
Thank you i thought i could get by without one with coils if i didn't go to low. I was hoping like 2.5 maybe 3 in front. Would that be to far out of spec?
Old Apr 29, 2012 | 10:55 PM
  #486
JaE35's Avatar
Moderator
G35 Sedan
Over or at 2 inches in the rear you'll need a camber kit.
Old Apr 30, 2012 | 06:45 AM
  #487
yeah i had 350z s techs and i was border line for the rear. What about the front though. no more than like 2 inches too? my buddy had df 210 and i'm pretty sure the front needed one.
Old Apr 30, 2012 | 11:44 PM
  #488
Algy's Avatar
You are going to need camber kits all around bro. Without them, your tires are going to run out unevenly.
Any drop is going to need camber kits. If you dont have any, then you are just going to run inner tire wear.
Old Apr 30, 2012 | 11:46 PM
  #489
JaE35's Avatar
Moderator
G35 Sedan
Fronts will be fine...you do any searching you'll see that most guys don't run front kits. The rears you gotta have
Old Apr 30, 2012 | 11:49 PM
  #490
Algy's Avatar
I have no idea how they failed. I just knew when I drove, the ride was squishy and not comfortable and bouncy. I heard a lot of squishy noises from the shocks too. Took them off the car and I tested it to see if they were still good.
I set the dampening to max soft, and the compressed the shock. It was suppose to rebound upwards but it didnt even do that. I had my BC coils next to me and I set it to max soft and it rebound upwards strongly.
Reason how I knew shocks were out. The only time its suppose to not come up is when you have it on max stiff. But even still its suppose to come up but very slowly.
Old May 15, 2012 | 09:31 PM
  #491
Yeah but if i'm doping 2.5 to 3 in the front, my tires are done in no time. i actually just got a good deal on some Front camber arms. I'm sure that would be enough to take care of it.
Old Jun 26, 2012 | 09:30 PM
  #492
well i started to place my order when Racingfirst replyed back to me and said that they are all out of the yellow ones. They only have the red so i'm kinda sketch about buying those after reading about all these bad seals. I sent topspeeds ebay page a message about theirs but have not recived a reply yet. there ebay page says the item is Sold.
Old Jun 26, 2012 | 11:48 PM
  #493
NFSP G35's Avatar
? = 2B || !2B
Did you check the thread on My350z?
Old Jun 27, 2012 | 06:30 AM
  #494
Im gonna check it out but I wanna do the Bill me later on PayPal not sure if that's an option buying off their thread on there.
Old Jun 27, 2012 | 06:53 AM
  #495
He says the quality is the same just different color but Idk if I wanna go with them. I'm not looking for rear strut problems
