Just replaced my compression rod bushings, noisey?
Old Apr 4, 2011 | 07:52 PM
AuAltima3.5's Avatar
I just replaced my compression rod bushings with OEM replacements and they started making noise after about 1000miles.
When I turn the wheel at low speed or enter my driveway it creaks and pops.
I looked at them and still appear fine? What's the deal? I'm about ready to re-do them with energy suspension ones... am I crazy? My old ones were ripped and didn't even make noise, but I'm sure they were killing my alignment.
Old Apr 5, 2011 | 12:59 AM
Timmeh's Avatar
Did you do them yourself or take it into a shop? If you took it into a shop they should warranty the work and check it out free of charge, and make any replacements or adjustments.
Old Apr 5, 2011 | 02:15 AM
prinny's Avatar
lubricate?
Old Apr 8, 2011 | 09:45 PM
Update...
I spent two hours under the car a few days ago just turning the wheels with my hands from lock to lock.
It is NOT the compression rod bushings. It appears to be the whiteline bushings I installed that have either a) got an inner barrel just short enough to move in the K member (lower subframe), or b) it's the end link. I had rechecked the torque on EVERY fastener I removed for my transverse link/compression rod bushing install.
It's only the driver side. I lubed the transverse link bushing with some synthetic grease and it really stopped alot of the noise, so I'm thinking it's my trans link bush.
FYI for others. I don't think this is whiteline's fault, but perhaps something I did in my install. I had a shop press the bushings and I did the rest myself.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
