Alignment specs after drop with no kits
Old Apr 6, 2011 | 09:50 AM
JuicedAthletics's Avatar
These are my alignment result from S-tech springs with the rear spring mount cut to max ½”. The rear drop is lower than my DF210s I had before. I have no camber kits, this is just an alignment.
Front Specs
-1.9, -2.0 camber
8.7, 8.7 caster
.03, .03 toe
0.0 steer ahead
Rear Specs
-2.4, -2.7 camber
.04, .17 toe
-.07 thrust angle
Everything with the exception of camber is within spec (green). My question is about rear toe. I don’t mind the neg camber but should I buy SPC toe bolts to even out the toe in the rear? Or should I just leave it since it is within factory spec?
Thank you
Old Apr 6, 2011 | 10:17 AM
Xet's Avatar
Xet
I don't remember for sure off the top of my head, but I thought toe range was only up to 0.10? I personally would get a camber kit in the rear to even out your camber as well as toe bolts to pull that .17 side back in to match the other.
Old Apr 6, 2011 | 11:09 AM
These are the rear specs on the Infiniti guide
Camber -1.8 -.8
Toe 0.00 - 0.22
Everything is in green besides my camber (which I dont mind). Just didn't know if it was worth it to throw the toe bolts on there and try to even it out.
bjo16
Aug 4, 2015 09:52 AM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
