Rumbling noise when turning and squeaking noise when going over bumps??
Old Jun 30, 2011 | 06:10 PM
ImprezaSTi's Avatar
Hello everyone, having a little problems here with my 05 g35 coupe, auto...
When I turn right sharply at high or low speeds I get the rumbling noise. Also when I am going over bumps at high speeds I get a squeaking or chirping noise. Both the noises seem to come from the front drivers side wheel area. Does anyone know what the problem is? Bushings?
Thanks for the help!
Old Jun 30, 2011 | 09:25 PM
05Scoobyroo's Avatar
Is the rumbling noise occuring faster as your speed increases? If so, may be your wheel bearing on your driver's side.
Old Jul 4, 2011 | 07:47 PM
ImprezaSTi's Avatar
I dont think its occuring faster... just louder as speed increases
Old Jul 8, 2011 | 04:36 PM
AuAltima3.5's Avatar
Is it constant? Does it get louder when you turn right?
I'm guessing bearing. Take it to a shop or pull the wheel and check for noise/play. When bearings go out they don't always have play.
Old Aug 3, 2011 | 06:56 PM
ImprezaSTi's Avatar
Actually the noise does get louder and more constant as speed increases.
I brought the car to a local shop and they couldn't find anything wrong, maybe I will bring it into Nissan some other day.
I recorded the sounds and made a video, check it out:
Let me know if you know whats wrong! Thanks guys
Old Aug 3, 2011 | 11:16 PM
junon's Avatar
Regarding the rumbling, have you checked the inner side of your tire for any foreign objects or feathering? I had a similar frustration and it wound up being my tire itself wearing unevenly.
Old Aug 3, 2011 | 11:22 PM
ImprezaSTi's Avatar
Yes I am quite sure its not the tires. I recently got a new set of all season tires, and the problem still persists.
Old Aug 12, 2011 | 05:54 PM
deegaw11's Avatar
I have the same rumbling noise but it's coming from the passenger front. It's extremely loud no matter how fast or slow I'm going. Please let me know when you find out what the problem might be. Thanks
Old Apr 10, 2012 | 01:36 PM
bentotdagr3at's Avatar
I'm experiencing the squeaking/chirping noise like in the video.
What was the conclusion on this?
Old Apr 10, 2012 | 02:44 PM
ImprezaSTi's Avatar
Okay, hope I can help some of u guys here. I haven't fixed the rumbling noise and I have been driving with that. After doing some research it is probably the wheel hub. I have ordered the parts but have yet to find time to actually do the work.
But I have fixed the chirping noise! It was very simple. The noise was not coming from the suspension, it was the front fender body panel that had a loose screw allowing the panel to loosen and make that noise. What you can do if u have this noise is to push with ur hands on the corners of the body panels on ur car and should find it!
Old Apr 11, 2012 | 12:07 PM
Nice!
Found it. I'll try to drive it later on and see if that fixes it.
As for your rumbling sound, I don't know if it's the hub. Most hubs don't go bad but the bearing does.
Try driving over 60km/h and try swerving left and right loading whichever side you think is making the noise. If the noise gets louder when one side is loaded with weight, by swerving, then it is your bearing.
Both my fronts went at the same time. I thought it was only the passenger side but after fixing that side my driver side was making the noise as well.
Good luck and thank you
G35Rican
Jul 31, 2024 01:37 AM
magnetism80
Feb 1, 2019 10:00 AM
kevintandmd
Sep 3, 2015 06:41 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
