Ichiba Camber Arms FTL!
Old Jul 15, 2011 | 03:22 PM
Adon's Avatar
Been hearing clunking getting worse and worse last few months, finally got under the car and saw what the issue is.... I wish I did more research on this specific product before I bought it for $300 !!!
Would putting some kind of different bushing in there fix this, cuz it looks like it's fckin up the hole there in the control arm, the whole thing just sounds like it's gonna fall apart when I go over bumps...
right now I cant even unscrew the bottom bolt that's being sucked into the hole, just keeps rotating when i turn it, and I doubt I can fit any kind of impact wrench in there, i was thinking about putting a washer between the control arm and the bolt to secure it tight.
There is no beating around the bush, this is a straight up faulty design on Ichiba's part, they must have idiots working in quality control
this is how tight the bottom screw is supposed to be, notice the big red fat bushing that does it's job as well
OH AND BTW, IS THIS NORMAL ?? looks like it's not hubcentric enough, there is some room for movement here, i've been hearing a smaller noise when driving exactly like when you get a rock stuck in the tire tread and you can hear it contact the pavement every time the wheel turns....
but once i step on the brakes the noise disappears so it has to be something with the brakes, and this is the only part of the brake system that seems loose to me after a close inspection... these are R1 concept rotors by the way... zinc coated for rust proof eh, look at that rust
Old Jul 15, 2011 | 03:35 PM
Adon's Avatar
and the cherry on the cake, i just called their official number listed on their crappy website (626) 962-3784 aaaaaaaaaaaaaaaaaand it`s out of service !
EDIT: called one of their dealers SP engineering and they were kind enough to give me their direct new line 626-226-0899...
just got off the phone with a lady rep there, she told me to email them with this video clip a technician will take a look at it and i should have a response next week
Old Jul 15, 2011 | 04:00 PM
Xet's Avatar
Xet
You paid $300 for front camber and bought an ichiba?
Sucks that now their front and rears turn out to be crap. Why did you go with them when they don't even offer good adjustment?
Old Jul 15, 2011 | 05:57 PM
DogStar's Avatar
SPC was extremely helpful when I had questions or anything with mine. Given your ride height and how much you have invested in your stance tho I'd go with SPL and be done with it should you have to replace them.
That sucks tho man. hope everything works out.
Old Jul 15, 2011 | 06:52 PM
Blue Dream's Avatar
I drove ttrank's car solo
Not surprised, I've had 4 Ichiba products on my car and they all failed in some way. Rear camber arm, 15mm V2 spacers, 5mm V1 spacers, and toe bolts. I will never waste my money on their shizz again.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
