I need to replace the following items but I just want something better then original. Can anyone can help me with this items but in the aftermarket although I don't need adjustable if any, but if you recommend me it, I will get it.
54500-AM601
54501-AM601
54468-CD002
54469-CD002
54500-AM601
54501-AM601
54468-CD002
54469-CD002
faiz23
close
- Join DateNov 2006
- LocationYour mom's bed
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:291 Times in 218 Posts
Why would you link part numbers that is a$$ backwards. Look like it is end link and compression bushing. Research on SPL and power grid along with energy suspension
54500-AM601 <<Suspension Control Arm Right
54501-AM601 <<Suspension Control Arm Left
54468-CD002 << Compression Rod Right
54469-CD002 << Compression Rod Left
faiz23
close
- Join DateNov 2006
Okay why are you replacing these parts. Are you lowered or they are worn out. More info would be nice like year, body style and RWD or AWD. You should look at SPL upper control arm and energy suspension bushing for compression rod. Rarely does the rod go bad and only time to change the rod is when the ball joint is gone. Most common issue is the bushing getting torn and creating alignment issues / tire wear. You really need to do a better job with asking for help...this thread is hurting my head.
04 coupe 6spd rwd lowered, and yes the ball joint has gone bad, that is why I need to replace this parts.
faiz23
close
- Join DateNov 2006
Part # Details Per Car Stock In-Store Online G35Driver Price
54469M 54469CD00C ROD COMPL-TENSION,FR 01 In Stock $261.94 $188.60 $161.09
54468N 54468CD00C ROD COMPL-COMPRESSIO 01 In Stock $261.94 $188.60 $161.09
okay the last part you need the lower control arm or upper control arm. I think you linked lower control arm. What is wrong the bushing or you need to replace the whole part. I would get spl or energy suspension bushing to press into the new compression rod or you will be doing it again down the road. You can just buy a bushing for the LCA unless for some reason you need a complete set.
Sewell has some good prices on parts fo G35 members but do your research and see if you can find better prices.
http://infiniti.sewellparts.com/oem-...oupe-2003.html
If you want something other(not necessarily better-these products are new and not time-tested) than original, then replace the bushings(~$120 for complete front energy suspension kit) and lower ball joints (search ebay). If upper A arm ball joints are busted, then get replacement A arm-same ebay.
If you have deep pockets, then get factory parts and you'll be OK for next 50K miles.
Search button also helps.
https://g35driver.com/forums/brakes-...ism-guide.html
Tags
54468cd002, 54468n, 54469cd00c, 54500, 54501, aftermarket, am601, arm, compression, g35, infiniti, lower, part, replace, rod, wanted
