Camber adjustment on SPL front A arms
Old Aug 31, 2011 | 09:54 PM
Blue Dream's Avatar
I drove ttrank's car solo
Well I feel like a n00b posting this but I wanted to share my newfound knowledge with the Driver family. Thanks to MikeGrote for bringing this to my attention.
I bought the SPL arms a year ago and have wanted more positive camber adjustment. I'm dropped ~ 3" from stock and the best I could get was -2 degrees camber up front with all of the shims installed in the arms. I was about to contact SPC to see if they would sell just the spacers and ABS bracket separately that are included in their front camber kits and discovered my arms still had some positive camber adjustment left. MG was told by SPL that by unscrewing the heim joints at the end of each arm an inch we would get an additional 1.5 degrees of positive camber. Why the fvck didn't I think of that before I wondered? Here's a couple of pics for reference:
Arms
Heim joints
The one on the left is from the V2 arms and the one on the right is from the V3. If you have V2 arms, SPL will send you the V3 upgrade for free FYI.
SPL did suggest that to be safe they recommended only unscrewing the joints 3/4" but that's still 1.15 degrees of positive camber and would put me back squarely in factory spec if I had that much room to play with. Unfortunately I don't due to fitment issues, but measuring my gap between the sidewall and fender I have about 3/8" so that's over 1/2 degree adjustment which will certainly help with my front tire wear.
So if you have these arms and already knew that feel free to flame I feel really dumb for not figuring this out on my own but thought if I posted this it might help someone else.
That's all, thanks for reading.
Old Sep 1, 2011 | 12:44 AM
jookyshank's Avatar
I haz hugz to givez
Good lookin out...I love me some SPL...they think of EVERYTHING!
Old Sep 1, 2011 | 12:51 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The only thing you have to be careful of with this is the arm hitting the point where the inner fender meets the body of the car.
Old Sep 1, 2011 | 01:21 AM
Frankieg35's Avatar
U really get what u pay for with these bad boys!!
Old Sep 1, 2011 | 05:39 AM
Blue Dream's Avatar
I haven't had that issue but I have had the bottom of the A arms hitting the top of the OEM radius arm. I didn't grind the bumps of the OEM arm off as suggested though so I think that would cure my clunk.
Old Sep 4, 2011 | 10:19 AM
Blue Dream's Avatar
For anyone who cares I adjusted my arms last Tuesday and have put about 400 miles on the car and they are solid as a rock. I only adjusted them out 3/8" which I calculated to be about +.5 degrees of camber. Haven't taken it to the shop to confirm numbers, will do that next week. Tires are exactly where I want them from a fit perspective and I should be somewhere around -1.4 on the fronts ATM.
Thanks again to MikeGrote for revealing this info.
Old Sep 4, 2011 | 12:05 PM
G35sedan03's Avatar
what is the range of these? i remember at the time when i bought my SPC arms years ago, they offered the most range for adjustment, up to +5 adjustment for those with some serious neg camber issues.
Old Sep 4, 2011 | 12:29 PM
broke_as_ajoke's Avatar
Can caster be achieved with SPL?
Old Sep 4, 2011 | 01:42 PM
MikeGrote's Avatar
Glad I could help, but you mention you are supposed to grind something down? Is this mentioned in the instructions? I haven't ordered my arms yet
Old Sep 4, 2011 | 01:46 PM
MikeGrote's Avatar
I'm not exactly sure on the specs for the spl, but the spc arms get such a high range by including hub spacers with the arms. For those of us planning to do an akebono brake kit, these hub spacers will not allow the adapter from the brake kit to work, therefore without the hub spacers, much less adjustment with the spc arms
Old Sep 4, 2011 | 01:49 PM
MikeGrote's Avatar
Yes, when I talked to spl he confirmed this also. You use the same heim joints referenced in the original post, but you just unscrew one more than the other. Depending which way you want to go with it will dictate which one needs to be unscrewed more
Old Sep 4, 2011 | 01:57 PM
G35sedan03's Avatar
got this from their website, check it out http://www.splparts.com/instructions/SPL_FUA_Z33.pdf
Old Sep 4, 2011 | 02:05 PM
Blue Dream's Avatar
Yep, those are the bumps I was talking about. The bottom of my A arms is scored where they rub. I've just been too lazy to do this.
Old Sep 4, 2011 | 02:14 PM
G35sedan03's Avatar
i went with the megan BBK years ago, before the akebono kit was an option. with that kit, i have not had any issues adjusting camber. and to be perfectly honest, i'm very happy with the megan BBK. i know the akebono is a great buy for the $$$, but i got mine on a GB and the price was too good to pass up.
Old Sep 7, 2011 | 01:28 PM
Haha, you and me both Tim! My arms are all banged up on the underside from the bumps. It's funny that I cut then off when I install the arms on other G/Z's I work on but not my own!
