Ok I just purchased rear brake pads and rotors and while I was trying to unbolt the two bolts (14mm) to take pads off I stripped one of the bolts and stripped the hexagon to where its rounded off. So I was wondering if some one might know the bolt number so I can purchase it from infiniti. I have searched and searched and have found nothing so I figured id ask on the forums to see if I can get help. Thanks a lot in advance
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Quote:
Not a good idea....^....any bolts having to do with the brake area should be grade -8 bolts and most hardware stores don't carry anything close. You're going to have to wait until Monday and either visit Nissan or Infiniti for the right bolt. The independent brake/alignment shop I use carries both the nuts/bolts cause they're easily broken and not avaliable every where.Originally Posted by herrschaft
You could take one of the good bolts to a hardware store and find a replacement. I had to do that but can't remember the size.
Gary
herrschaft
close
- Join DateJul 2009
- LocationCoast
iTrader Feedback Score(18)
Liked:771 Times in 605 Posts
^Didn't know it was supposed to be 8. Since the bolt I bought has held for a year now with a 6-pot caliber it was probably the correct rating.
B L U E S L A T E
close
- Join DateApr 2007
iTrader Feedback Score(15)
- My RideHonda Accord
Liked:80 Times in 65 Posts
Call up a local Infiniti parts department. If you're in SoCal,, hit up Tony or Rick from OC Infiniti.
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
I fukked my bolt up taking it out and I went to infiniti and they just gave me one they had laying around off a old set of calipers..
The caliper bolts? Autozone sells those. Have you gotten the old bolt out yet?
auto stores with have that bolt. you dont need a bolt number just take one of the good bolts with you and they will match the thread and size for you.
Quote:
I haven't got the old bolt out yet. Gonna have to get some kind of kit to take out stipped head bolts. I actually ordered a bolt from infiniti and it ran me 4.50 which ain't that bad I guess.Originally Posted by cameronb
