Need to replace 350z suspension
Old Oct 12, 2011 | 09:22 PM
olopez's Avatar
I've been running a full 350z for a couple years now. I got it used & think its time to replace the fronts. Rears are fine. The ride isnt as smooth as before. I bottomed out on a big speed bump, which made me think it was time to replace the struts. Should I replace the struts only? Springs too? Any suggestions? Brands?
Old Oct 13, 2011 | 10:12 AM
4D05G35's Avatar
No need to replace the springs, just buy some good shocks/struts and you should be good to go. Check your compression rod bushing while you're there.
Old Oct 13, 2011 | 01:29 PM
olopez's Avatar
Thanks for your help! Do you know which strut/shock would be a good replacement for a 350z? I want a smoother ride now (GF complaining lol).
Old Oct 13, 2011 | 05:27 PM
High_Boost's Avatar
the most comon replacement would be the tokico blue which cost ~$300/set online
it sounds like you may be best served by getting the tokico D-Specs which are adjustable (so you can mane them softer if needed), but they cost twice as much
Old Oct 13, 2011 | 05:44 PM
olopez's Avatar
Thanks for the suggestion! I was looking at those online. I found the front set for $160 shipped.
Old Oct 14, 2011 | 08:15 AM
4D05G35's Avatar
+1 what I would do if I were in your shoes. The Tokico blues are great, but (pertaining to the g) they are kinda harsh as I found. If they were adustable (D-Spec) I would soften them a little.
Old Oct 14, 2011 | 02:59 PM
olopez's Avatar
So are you saying the Tokico blues would be harsher/stiffer than a 350z (revised springs) or G35 stock suspension?
Old Oct 15, 2011 | 12:51 AM
4D05G35's Avatar
I had the non-sport suspension so to me they seemed harsher/firmer. I have heard of others comparing the HP's to the sport suspension (as far as firmness and ride quality).
Old Oct 15, 2011 | 11:25 AM
olopez's Avatar
Cool thanks! I went from a non sport to a 350z w/revised springs. It was firmer in a good way. If the tokicos r the same as when the 350z sups was new I'll be happy!
rezendvous420
May 31, 2020 01:26 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
CJay
Aug 1, 2015 03:57 AM
xplosive1
Aug 1, 2015 03:01 AM
atk08
Jul 30, 2015 03:12 PM
