anyone experienced problems with the bushings? G35 coupe
#31
What's sort of nutty is - I paid $287 for the LCA's and Compression rods (alone still a great deal).. But I could have kicked up another $113 and gotten ALL OF THIS:
http://www.ebay.com/itm/Nissan-350z-...item257b8635f3
DOH!!!
I have half a mind to ask to fill out the order for the whole kit somehow if they'd be willing.
Mind you the ball joints are OEM replacement spec.. Speaking of that - which ball joints to you use / suggest for lowered applications (I'm on simple Tien Basic's myself). I took an online look at the "Moonface" ones, but honestly, $600+ for two ball joints is extremely unfriendly pricing :/
DOH!!!
One other thing... for the end-links don't settle for OEM replacement. I have SPL and have no complaints. Whiteline are quality as well from what I hear.
#32
I just had nissan replace my lwr control arm bushings and they found my compression rod bushings were bad.I didnt have any shaking or noise! Just at 80 on the interstate had alittle vibration. They also aligned the frt and rear. Cost me $100 I had extended warranty. It handles great always did!
#34
As it happens - they totally let me pay the extra balance and shifted me the remaining parts of that kit... so I got the whole kit and kaboodle!
I've already installed the front lower control arms and sway-bar end links - which turned out to be a LOT easier than I'd expected - and I even attempted the ball joints. But MAN I can NOT figure out that stupid Auto Zone Ball Joint Press thing to save my life! I'm currently doing a bit of research on the ball joint topic now - and it's looking like just taking whole knuckle(s) off and down to the corner shop for a $30 press out/in is the way to go LOL
#35
DOES ANY ONE HAVE ANY DIY ON THIS LOWER CONTROL ARM? I JUST HAVE 2 MAIN QUESTIONS. I COULDNT FIND ANY WHERE REALLY![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
1. IM I GOING TO NEED ANY SPECIAL TOOL TO REPLACE THE WHOLE ARM.?
JUST BAUGHT THE WHOLE THING AND I DONT WANT TO PRESS ANYTHING IN OR OUT AND IT LOOKS LIKE THE BOLT THAT GOES BEHIND THE WHEEL IS PRESSED IN (HOPE NOT)![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
2. IS IT TRUE THAT THE BOLT THAT GOES THREW THE SHOCK HAS TO BE TIGHNED WHEN WHEELS ARE ON THE FLOOR ? OR IS THAT THE OTHER BOLT GOES THREW THE CHASSIS....![Confused2](https://g35driver.com/forums/images/smilies/confused2.gif)
#36
I just did this and all I used was:
24" Ratcheting Breaker Bar with 1/2" drive (even an 18" would do really)
Torque Wrench
PB Blaster Penetrating Lubricant to prep the bolts for removal
Floor Jack (having two would be useful but not needed, as long you have a:
Jack Stand
A second large 1/2" drive Socket Wrench (not breaker bar size, just big)
The appropriately sized short and deep well sockets
A pair of needle nose pliers for the cotter pins on the LCA balljoint bolts
As to your second question, that relates to having either two jacks, or a jack and a jack stand:
In order to tighten everything up correctly, you have to have the geometry of the control arm assembly in the right position (like it would be on the ground with the cars weight on the tire). In order to do this, you jack up the car and then put a jack stand at it's lowest setting (or second jack just jacked up a little bit) under a point of the sub-frame that's safe to hold the car up. Then using a floor jack, with the new control arm in place with all the bolts and nuts are in/on but not tightened up (still hand loose), put the jack cup under the ball joint in the steering knuckle and jack up the suspension assembly until you're just *barely* lifting the car from the jack stand. At this point you've the full weight of the car at that wheel's location.
This way, you've got the parts all in the same places they would be when the car is sitting on them - from there you can tighten it all up using the torque specifications called for in the FSM... which I think is pictured here in this thread - or you can just reference the free PDFs available for our car here:
http://www.nicoclub.com/FSM/G35/
Hope that answers your questions
Torque Wrench
Jack Stand
#39
#41
#42
Getting it all to work together is the hardest part. Just keep messin with it and you'll find an angle where it works.
#44
Anytime you mess with front end parts your alignment gets way screwed. I would suggest investing in a lifetime alignment from Evans or firestone or someplace.
You'll most likely get a clunk if that crown nut is loose and I would suggest going to a shop and asking if they can tighten it. May charge you $20, but that's sorta dangerous to drive around with loose suspension parts.
#45
![JAMIN](https://g35driver.com/forums/images/smilies/jammin.gif)
