anyone experienced problems with the bushings? G35 coupe
My car had lowering springs and sometimes my car hits the control arms when I go through driveways. Anyways, I changed the springs to the stock ones and now the steering-wheel is shaking when I drive my car.
I noticed that the bushings (rubbers) are almost worn out. Does that make the steering wheel shake? Do I have to replace the whole controls arms or is it possible just to change the rubbers-bushings?
Not sure what is causing your issue specifically, but once you lower your G, you will put wear in a few suspensions parts that will have to be replaced quickly, so you might want to get it done all at once. It might solve your problem, and if not, it will have to be done soon anyways. The items are:
Front Inner Control Arm Bushings. (It seems like you might be having issues with the outer one too. But you can only replace the bushings, you don't have to replace the whole arm)
Compression Rod Bushings (all four)
Replace endlinks if your car is older than 2005 (when they revised the endlinks and replaced them with much sturdier ones)
Also, if you only lowered and didn't change the shocks, you might have to replace your shock mounts soon.
Good luck.
Good luck.
I drove ttrank's car solo
Received 1,486 Likes
on
That's a common issue with all Gs, not just lowered ones. A few companies make replacement bushings including SPL, Energy Suspension, and Whiteline. You can remove the control arms and have the old bushings pressed out and new ones pressed in. The aftermarket bushings should last a long time.
Or you can just buy new arms, they're about $190 each if you shop around, and just replace the whole thing. Same theory applies to the compression rods and rear differential bushing.
Thanks
I called the dealership and they don't sell the bushings seperately, they told me I have to buy the whole arm and it costs $270 each...Do you know where can I buy the bushings only?
and for the compression rod bushings, they sell them for ($72 each). I think it is over-priced what do u think?
One more question because I wanna make this clear
For the ((front inner control arm bushings)) they have Front UPPER arm bushing and Front LOWER arm bushing. So which one should I get?
And when u said buy all 4 Compression Rod Bushings. Are these for the FRONT and REAR tires? or the front has 4 bushings? so total will be 8 bushings for all four tires?
Thanks a lot!
Thanks a lot!
on
Thanks
Thanks a lot!
Thanks a lot!
There are no compression rods on the rear of the car so no worries there. Here are a number of links from our marketplace that list different types of bushings and sets. Look through them and PM the vendors with any questions you might have, I'm not going to do all of your work for you.
https://g35driver.com/forums/suspens...shing-kit.html
https://g35driver.com/forums/suspens...inks-more.html
https://g35driver.com/forums/suspens...-bushings.html
https://g35driver.com/forums/suspens...-them-out.html
The following 2 users liked this post by Blue Dream:
G35inNC (03-06-2014),
ThatOneDude (10-13-2011)
on
on
I guess I need to be more direct, SMH. This site is great because of the help we offer each other. HOWEVER we will not spoon feed you, we expect you to do some of the work yourself. So follow my advice, PM any of the vendors I listed, and ask away. It's not that hard, really, and you'll have a boost in your confidence for doing something yourself.
Footballmania32 (11-02-2011)
As blue dream said, we can only go so far with the advice.
Usually there's only the need to repalce the inner lower bushing, but now it's your turn to use the Search button, and browse thru some pictures of the whole assembly and how to detect whether both need to be replaced.
We are here to help, but we can't look behind your wheel wel for you, or test drive your car to pinpoint it with that much accuracy.
When it doubt, drop/add spacers.
Replace the whole fukn thing. Nissan initially issued a revised rod and bushing. Since the original one is out of spec causing premature wear on the bushings.
Replacing the bushing alone with a "revised' bushing might work.
If it were me, I'd replaced the entire fuking thing and get it done right the first time. Cost of Labor is a biotch. So do it all at once.
