Espelir Springs?
Old Nov 7, 2011 | 10:42 AM
Bastone's Avatar
Espelir Springs?
Looking to drop my '05 X and there's a guy local to me that's selling some Espelir springs off his sedan. No luck searching online, anyone have any experience with these?
If it helps, they're a baby blue colour.
Old Nov 8, 2011 | 11:06 AM
Bastone's Avatar
No one?
Old Nov 9, 2011 | 12:44 PM
4DGS's Avatar
Espelir is a quality company (They're mackin same company as Rays AKA Volk)
But to be honest I have never owned or installed their springs. However, I would trust them to be quality, so if they are the drop you want then go for it.
Old Nov 9, 2011 | 03:10 PM
Jairen's Avatar
I have a set of Espilr springs thanks to another member of the forums.
Check out the suspension thread for the spring rates.
It rides fine but to be honest, the spring rate is a little stiff for the OEM struts.
Old Nov 9, 2011 | 03:20 PM
Bastone's Avatar
So the stiffer spring rate, would cause a bouncier ride or a rougher ride?
Old Nov 9, 2011 | 03:40 PM
Jairen's Avatar
To be honest, the ride wasn't bad at all.
The only time I would feel it was when I would hit big dips in the road. The OEM shocks could handle the rebound of the stiffer spring rate.
I would suggest aftermarket struts like d-specs, but I think the spring rate is still a tad too stiff for d-specs according to Tokico. Should be fine though.
Old Nov 9, 2011 | 04:18 PM
Bastone's Avatar
Ok.
Here are the pics from the guy selling them. Think I'll need a camber kit?
Old Nov 9, 2011 | 04:26 PM
JaE35's Avatar
Moderator
G35 Sedan
no, you will not just get a good alignment
Old Nov 9, 2011 | 05:58 PM
Bastone's Avatar
Ok sweet. I'm gonna have the service department at my work do the install + alignment.
Old Nov 9, 2011 | 06:00 PM
Jairen's Avatar
With mine, it's only a small drop (per Espilir) and it took me to about -2.2 front and -2.5 rear camber. I have a coupe though.
You may be getting the sedan springs which have a softer spring rate and drop.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
