How bad is my alignment? And How bad will tire wear be?
Old Nov 20, 2011 | 12:14 AM
916TownG35's Avatar
I'm not sure of how much more life my tires have so I just wanted to ask you guys here.
Old Nov 20, 2011 | 01:11 AM
Xet's Avatar
Xet
what are your rims? offsets? drop? camber kits?
Your rear toe isn't very good which will be the biggest difference in tire life.
Old Nov 20, 2011 | 01:14 AM
916TownG35's Avatar
Stock 18's and about a 1 - 1.5 inch drop not sure. U think if I raise it some of this will be fixed.
Old Nov 20, 2011 | 10:05 AM
Xet's Avatar
Xet
That's way off then, 3 degrees in the front and 3.5 in the rear with bad toe sounds like someone aligning it who has no idea what they're doing. 1.5" drop could mean you need camber kits, especially in the back but 3+ degrees from that small of a drop is ridiculous. I wouldn't pay for that kind of an alignment.
Old Nov 20, 2011 | 10:33 AM
Texasscout's Avatar
I'm dropped 1" and I got mine back in spec (barely), but I still have inner tire wear.
Old Nov 20, 2011 | 11:08 AM
faiz23's Avatar
Here is my alignment and I am dropped on Z/G springs. I would get a rear camber arm kit with some toe bolts ASAP if you want your rear tires to last. The front could benefit from camber arms as well if you have some funds. What I would do is try to get total toe in the front to about .1-.2 and the total toe in the rear should be .08-.12.
This is a decent alignment and I went with NTB who pricematched a local place for $39.99 for 6 month alignment and I was with the technician in the back dialing in each wheel and choosing the ideal setting.
Old Nov 21, 2011 | 12:20 AM
916TownG35's Avatar
I lied about the drop, I'm about a 2.5 inch drop.
Old Nov 21, 2011 | 12:43 AM
NATH_19's Avatar
WWAAATTT ???
Old Nov 21, 2011 | 01:01 AM
redpearl99's Avatar
your toe is just barely within spec but with 3 and 3.5 camber dont expect your tires to last too long
Old Nov 21, 2011 | 01:21 AM
dofu's Avatar
20 Year Member
Your toe looks fine. You need the rear toe, and the 0.03 degrees toe in on the front wheels will be closer to 0 when the car is under load. The camber is what I'd be more concerned about, although it really isn't that bad. All in all, I'd say your tires can last a year or so of daily driving, depending on the type of tires you're running.
Old Nov 21, 2011 | 06:04 PM
916TownG35's Avatar
I'm running Michelins with 500 wear rating. front tires are as follows, 30% inside 40% middle 50% outside. Rear tires are 50% inside 50% middle and 60% outside.
Old Dec 22, 2011 | 10:22 PM
xxx4reggie's Avatar
hey 916, where in EG are you?
I just got my G's alignment done at Firestone also, mine is almost like yours.
I'll upload mine. Let me know if you around, would love to meet another G owner thats in the area
P.S. I went to the roseville one instead of the E.G. Firestone, better service
i have the Tanabe NF210 springs with stock 18" rims. no camber kits as of yet
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
ScraggleRock
Aug 11, 2015 10:16 PM
wuppiedog
Aug 7, 2015 11:16 AM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 23, 2015 09:26 AM
