Urgent Suspension Question
Old Jan 15, 2012 | 02:19 AM
g35SedanSC's Avatar
Question Urgent Suspension Question
Does Energy Bushing knock compared to worn out compression rod bushing,after installation the knocking sound went away but sometimes the knock does come back.
Is it me or is it true.Thank you
Old Jan 16, 2012 | 05:37 AM
Blue Dream's Avatar
I drove ttrank's car solo
It's not the bushings you replaced, something else is knocking. Inspect your front end links, they might be the issue.
Old Jan 20, 2012 | 10:21 PM
g35SedanSC's Avatar
thank you.
this is the conclusion i came too,can it be the ball joints?
Old Jan 21, 2012 | 06:57 AM
Blue Dream's Avatar
Both of my front ball joints are toast and they don't make any noise so I suspect the answer to your question is no.
Old Jan 31, 2012 | 05:33 AM
g35SedanSC's Avatar
Since i changed my bushing,the knocking got even worse,mechanic told me its the bushing that are knocking,if its not the bushing what else could be. Thank you.
Old Jan 31, 2012 | 06:32 AM
Blue Dream's Avatar
Check your compression rods and lower control arms. They both have bushings that wear out and can make noise. Other culprits are the struts and end links as previously mentioned.
Old Jan 31, 2012 | 07:50 AM
g35SedanSC's Avatar
the knock is coming from my right passenger side,i have changed the bushings but the knock is still there....i really give up,i am ready to give it to the stealership for service
but why does my steering pull at the same time?
Old Jan 31, 2012 | 07:51 AM
g35SedanSC's Avatar
the ball joint on the compression is pretty fd up,but that doesnt really make sence...
Old Feb 3, 2012 | 07:39 AM
Onibaku's Avatar
I also replaced my control arm bushings (Energy) this week and experienced some noise when turning the wheel at a full stop. I'm hoping to get it looked at today. My ball joints look bad, but figured I had a few months left on them. Let us know how it goes!!
Old Feb 5, 2012 | 01:11 PM
g35SedanSC's Avatar
i am getting few different opinions on the knock that my car is making.and i dont see a point on changing everything since my ccar is 2004 and its just a work-DD.
opinions are
tie rods
ball joins
bushing
control arm
hub assembly
now its the fun time to figure what it is
Old Mar 8, 2012 | 04:54 PM
g35SedanSC's Avatar
ok after 1200$)))
this was done...
changed 4 struts and tein spring,lower and upper ball joints as well,and no more knock,the car feels awesome.
if anyone has any question please feel free to ask.
Old Mar 13, 2012 | 09:01 PM
axerickson's Avatar
How'd you do all that for $1,200? That's my question. Where'd you get the parts?
Old Mar 13, 2012 | 11:42 PM
g35SedanSC's Avatar
Lol actually this is the list of parts I changed
Struts
Tein hi-tech
Upper and lower ball joints
tyranny flush
Diff oil change
ngk spark plugs.done in Vancouver
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
