Adjusting front Toe
Old Jan 15, 2012 | 06:48 PM
OBsessed's Avatar
Adjusting front Toe
Sorry in advance if this is a stupid qeustion, but I've searched on google and the boards and haven't seen quite enough info yet.
I dropped my car quite a bit more than I probably should have and need an alignment, unfortunately my front Toe is so far out/negative that it just doesn't feel safe to drive. So I need to adjust the tie rods to bring it a little bit closer to normal before I take it for an alignment since the closest shop is about 15 miles away on 45+ mph roads.
As I'm adjusting the tie rods to bring the toe at least closer to where it should be, what's the recommended process for that? Should I turn the wheels so I can get a wrench in there or should I jack the car up and make a best guess? I didn't know if the resistance of the tires on pavement would make it more difficult than it should be or if that's the best way to go to eyeball it.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
itschuckster
Jul 25, 2015 08:07 AM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
