SPC Front Arm Camber Adjustment
Old Jan 15, 2012 | 11:19 PM
_FrankStarks_'s Avatar
Hello,
So I went to get an alignment done today and the mechanic says he can't adjust my front camber due to the limited space between tire and fender (I'm lowered pretty good in the front) am I ever going to be able to put my camber kit in the front to use or am I doomed to -3 camber in the front?
Old Jan 15, 2012 | 11:36 PM
redpearl99's Avatar
what are your wheel specs?
Old Jan 15, 2012 | 11:45 PM
herrschaft's Avatar
Mechanic sounds lazy. Not sure of your setup but can you post a pic of how much room there is between the tire and fender when the suspension is uncompressed. I have the Tanabe coils and I can access the A-arm when on a lift.
Old Jan 15, 2012 | 11:52 PM
Frankieg35's Avatar
He's being lazy!! Gotta jack up the car adjust it if there is no room..
Old Jan 16, 2012 | 12:39 AM
I guess I'll go in again tomorrow to see if they can do it again...thanks for the fast replies btw my wheel specs are 9.5 +0 in front and 10.5 +0 in the rears.
Old Jan 16, 2012 | 04:49 AM
DrewDrew's Avatar
If they aren't willing to take off the tire to gain full access to the a-arm, take it to another place who will take the time to get your specs right. You really need to have an in-ground jack or an independent car jack/hoist where the suspension can be decompressed, that way you can take off the wheel to get to the adjustment point and freely move around.
I drove over 80 miles one way to get my alignment done by Henry at Temple City Auto. People at this type of place have this kind of jack:
http://www.templecityautorepair.com/images/IMG_0004.JPG
So that you can take off the tire, adjust, put back on, compress the suspension and get your alignment specs. - That's what you're looking for, and most importantly someone who is willing to take the time.
In short, yes, you can get your front camber back in spec, just find the right place that is knowledgeable/willing to take the time to get it right.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
cbax
Aug 17, 2015 07:41 AM
Fireman07603
Aug 9, 2015 06:00 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
