Front lower ball joint boots
Old May 25, 2013 | 02:18 PM
  #46
Naveed2126's Avatar
Originally Posted by Eric@TCGMiami
I've had them for quite some time with the ES boots and honestly I haven't looked back since.
with many ... many miles put on them and some even tracked.
I ordered these and was going to install them, but the ES boots recommended seem shorter than the boots that came with the ball joints from Auto Zone. Did you have that issue?
Old May 25, 2013 | 03:05 PM
  #47
monster520's Avatar
ES boots are shorter but haven't had any issues. Only have had them on for 2-3k miles. Did notice they didn't have that muffin top like the oem style. Nothing leaking so I'm happy. Fitment looks perfect once installed.
Old May 26, 2013 | 11:40 AM
  #48
Naveed2126's Avatar
You used the ES 9.13130 ones, correct? Idk, they just looked maybe half an inch shorter, so I thought maybe I got the wrong ones. I guess I'll attempt swapping those in. Thanks for the feedback.
Old May 27, 2013 | 02:36 PM
  #49
monster520's Avatar
that's the part number I used. This is how they look when all torqued down.
Attached Thumbnails Front lower ball joint boots-ballj.jpg   Front lower ball joint boots-balljj.jpg   Front lower ball joint boots-balljjj.jpg
Old May 27, 2013 | 02:41 PM
  #50
Naveed2126's Avatar
So I did mine yesterday, and the old ones still had some life left in em according to the mechanic. My mechanic wasn't too crazy about the Auto Zone ball joints, even though I used ES boots with them. He told me I should've looked for Moog brand ball joints instead. Which I don't even know if Moog makes these for our cars. Overall, it was annoying to get the old ones out, but everything was easier thereafter. Thanks for the assistance guys.
Old May 28, 2013 | 01:26 AM
  #51
Eric@TCGMiami's Avatar
correct
and that's how it'll look!
Old Jun 18, 2013 | 08:23 PM
  #52
AARONHL's Avatar
Just ordered these........
Old Jun 18, 2013 | 11:08 PM
  #53
joedaddy1's Avatar
What are the symptoms of a bad lower ball joint?
Old Jun 22, 2013 | 05:31 PM
  #54
AARONHL's Avatar
Some success today, will post pictures after a time to shower and relax
Old Jul 16, 2013 | 03:19 PM
  #55
68_GT's Avatar
can I replace the ball joint boot with out removing the ball joint ?
Mine seem fine but I noticed one is torn.
Old Jul 16, 2013 | 04:19 PM
  #56
68_GT's Avatar
Do the ES boots fit on a OEM lower control arm ball joint ?
Old Jul 16, 2013 | 06:28 PM
  #57
AARONHL's Avatar
Check out the other ball joint thread
Yes you can replace just the boots, you will need to remove the conical spacer first. And yes the ES boots just barely fit they kinda ride up (check other thread)
Old Jul 16, 2013 | 11:18 PM
  #58
68_GT's Avatar
that thread showed the ES bushing for the compression rod ball joints. I wanted to confirm they work also for the lower control arm ball joints.
Old Jul 17, 2013 | 01:49 AM
  #59
AARONHL's Avatar
the bushing for the compression rod?? thats a completely different thing- there are no bushings on the lower ball joint
Old Jul 17, 2013 | 11:19 AM
  #60
P10 WRC's Avatar
Do the ES boots come with grease? If not, what kind of grease does Nissan recommend for this ball joint?
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
