If you have Drilled/Slotted/Dimpled rotors, I want to hear from you!
Old Jun 25, 2012 | 06:36 PM
DVG's Avatar
DVG
I am considering upgrading my OEM Rotors. My rotors are fine and have about 87k miles on them.
I am leaning towards Drilled + Slotted rotors because of the way they look (Yes I have searched and see that they crack more but its always the same 2 people saying they crack often). I am not sure if they're experience is common or not.
It is for looks only, the car is not track driven and will not be any time soon. Very important: needs to be durable and last just as long as my OEM ones have lasted me.
Also, I have generic replacement pads right now. Will those work with these rotors? I am not sure if the pads have to be made for drilled/slotted.
One last thing - I have no idea where to get dimpled rotors! They seem like the best bet.
Old Jun 25, 2012 | 06:40 PM
bluedevils95's Avatar
I too think they are cool but i will never get anything Drilled. To many problems. just get the slotted.
Old Jun 25, 2012 | 06:48 PM
jiggawuah's Avatar
if you go slotted though, they can't be resurfaced correct?
Old Jun 25, 2012 | 06:57 PM
MarkG's Avatar
Slotted, Yes. Slotted/Dimpled, Good. Both are a bit noisier as they scrape the pads than blank rotors.
Drilled, No. JMHO.
Old Jun 25, 2012 | 07:14 PM
DVG's Avatar
DVG
Ive never had my rotors resurfaced anyways...when you think about it, the brake pad is going to conform to the rotor and get good contact after you break them in and wear them down a bit....Even if the rotor is completely jagged, the pad will match it after a bit.
Old Jun 25, 2012 | 07:27 PM
DVG's Avatar
DVG
How do these look? Black zinc, say they come with lifetime warranty.
http://brakeperformance.com/brake-ro...ake-Rotors.php
From brakeperformance.com
Old Jun 25, 2012 | 07:30 PM
herrschaft's Avatar
I've had my slotted rotors resurfaced before.
Old Jun 25, 2012 | 08:31 PM
AARONHL's Avatar
Look into the 05/06/07 brake caliper upgrade before you decide on rotors. I would suggest 07 G35 or 350Z OEM calipers, OEM pads, and drilled-slotted StopTech rotors for your 2003.
Old Jun 26, 2012 | 07:15 AM
DVG's Avatar
DVG
What is the reason for the upgrade? Does it give more stopping power?
Old Jun 26, 2012 | 10:34 AM
money042's Avatar
For longevity, I don't think slotted or the like will be as good as old fashioned blanks (OEM). When you cut slots or drill holes in a piece of metal, you're going to lose some of its strength. With that said, it doesn't sound like you're beat up your car (race, track, rally, etc), so I think, if you take care of them, they'll last just as long as your OEMs. The ultimate question is, will you be driving your car for another 87k? And if you're changing out your rotors, might as well change your pads. The generics will work, but it won't be much of an "upgrade" ya know?
Old Jun 29, 2012 | 05:38 AM
0t1's Avatar
0t1
2cents worth
slotted or dimpled rotors let the superheated gases disipate between the pad and rotor surfaces, and clean the surfaces giving more efficient, cooler braking. On a road car they will last a bit longer than OEM type. Although there is less contact area there is more braking.
Drilled rotors have the same effect and are very efficient, you just need to change them regularly as per racecars.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
alinero718
Sep 27, 2015 09:35 PM
