Suspension Seems to Wander in and out of Alignment?
Old Jul 7, 2012 | 10:33 AM
Mr. Brett's Avatar
Hey all,
So first and foremost, let me get everything set up. About two months ago, I noticed I was having feathering issues on my front tires. About the same time, my struts started showing signs of wear, so I went ahead and bought new springs (350z S.Techs) and struts (Stagg SHS struts), as well as replaced the LCA bushings, which I found were worn, with Whiteline bushings.
I went and got the car aligned (NTB fixed my toe issue, but I still have about 1.5* of negative camber on each side; I know this does not cause feathering). My problem now, is that I still have feathering issues. But only on one side, to the point where I can hear the tire roaring on the road. What's strange, however, is that at times, it will make so much noise that I can barely stand it, yet other times, it's quiet as a mouse.
Anyone ever heard of a suspension moving into and out of alignment just enough to cause a tire feathering issue that makes such a racquet? I'm wondering if it's ball joints, or maybe sway bar end links/bushings.
Any help would be appreciated. I may have to just start replacing all the little suspension parts piece by piece until I get this resolved.
Thanks!
-Brett
Old Jul 17, 2012 | 11:52 PM
crashnburn's Avatar
i got same problem.. bout to install my front and rear camber kits and my 4 new pilot sport tires.. most quiet tire made by tire rack standards.. gets a 9.1-10 for road noise..
damn noise drives me crazy, i will figure it out no matter what it takes.
Old Jul 17, 2012 | 11:57 PM
4DGS's Avatar
End links won't cause that.
You've got a bushing or a cam bolt that's messed up and shifting.
Take it to a shop and have them look over the rest of the bushings and what not.
Old Aug 13, 2012 | 06:46 PM
AARONHL's Avatar
Wheel bearing? And possible a steering rack issue??
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
