350z suspension on a g
Old Aug 5, 2012 | 10:47 PM
Dark Pony's Avatar
I've been searching and I just want to confirm before I order...I'm looking into ordering some H&R or TIEN Springs and I've read that if you buy them for the 350z but put them on your G35 it will lower it an extra 1/2 "
Is there truth to that? Also is it direct bolt on?
Also if I order for a 350z and my g is a 2006 what year g do I order for? Same year?
Sorry but I'm a total noob to the g world.
Old Aug 6, 2012 | 12:29 AM
M00CHER's Avatar
Yes that is true. And it is direct bolt on. But you also want to consider getting after market shocks as well... And yes, order them for the same year and you're all set!
Old Aug 6, 2012 | 12:42 AM
Dark Pony's Avatar
Awesome...are shocks a must? Car only has 35k miles on it...it's an 06
Old Aug 6, 2012 | 12:44 AM
M00CHER's Avatar
They aren't a must right now. But they will wear a lot quicker with the lowering springs...
Old Aug 6, 2012 | 01:35 AM
Footballmania32's Avatar
I installed Z S-techs with ~50k on the car and my shocks were absolutely toasted with 85k.
Old Aug 6, 2012 | 03:24 AM
Jairen's Avatar
Might as well change it all at once and top it off with some sway bars.
Old Aug 6, 2012 | 08:21 AM
Dark Pony's Avatar
Lol!
Old Aug 6, 2012 | 08:45 AM
antodiaz's Avatar
I had 350z's Pro-Kit on a G coupe for 25k and didn't have any problems with the shocks.
Old Aug 6, 2012 | 01:36 PM
Dark Pony's Avatar
Thank you guys for the input. I'll look into shocks but not sure if I'm gonna do them just yet, I will be doing them though ...so 2006 z suspension and I'll be good...now deciding between h&r or s techs ...seem to be the 2 lowest drops
Old Aug 6, 2012 | 06:33 PM
antodiaz's Avatar
I know the 350z's Pro-kit is not on your options but I definitely recommend it. The ride is really close to factory and it lowered the car close to 2 inches front and rear. here is a pic when I had it.
http:/Name:  1D8BE078-orig.jpg
File Type: jpg
Old Aug 6, 2012 | 07:05 PM
Dark Pony's Avatar
http:/
I think you just sold me one the Eibach pro kit lol. Looks perfect ...Any rubbing issues?
Old Aug 6, 2012 | 07:08 PM
antodiaz's Avatar
Not at all. I was running 25mm spacers on all 4 corners and I did not had rolled fenders. You will need a rear camber kit tho.
Old Aug 6, 2012 | 07:16 PM
Dark Pony's Avatar
If I got the rear camber would I be able to get away with not having to roll fenders or put spacers on?
Old Aug 6, 2012 | 07:20 PM
antodiaz's Avatar
I never rolled my fenders and I had 25mm (1 inch) spacers. I was also running factory 19 tires. Absolutely no rubbing even before installing the camber kit.
Old Aug 6, 2012 | 07:21 PM
Dark Pony's Avatar
I'm loving the pro kit I'm just wondering if the s techs might be a little simpler...I'm hoping to just put on just the shocks for now and not need a camber kit, spacers, etc.
