Stabilizer connecting rod not connected
Old Sep 9, 2012 | 10:56 AM
Ouija's Avatar
Hey guys,
A few days ago, I changed out all my springs with the Eibach Pro Kit and on the front passenger side I took out the bolt that connected the stabilizer connecting rod to the lower arm, when I was all finished and I tried to put that bolt back in, it wouldn't go in. I assumed it was stripped or something so I put it in as much as I could and I drove to Infiniti to get it checked out. When I got there I took a look at it and the whole end link was disconnected and the bolt wasn't there, but I wasn't getting any clunking noises when turning my wheel. I tried to get Infiniti service to help me but it turns out they "weren't taking any more appointments" at 1pm on a Saturday. I made an appointment for this Tuesday.My question is do you guys think it's OK to drive a little bit (since I have to go to work and back) with the endlink not connected? I'm gonna go over to pepboys and see if they can put it back in and bolt it down (since only Pepboys is open on a Sunday).
Sorry for the long post but I needed to give some background details
Old Sep 9, 2012 | 05:25 PM
Blue Dream's Avatar
I drove ttrank's car solo
You'll be fine for a little while but I wouldn't drive it like that for more than a couple of days. If you installed your springs yourself, you should be able to fix the endlink. Just jack up your car, put some load on your suspension (I'd recommend putting the jack under the wheel hub and slowly lifting the hub) and you should be able to slip the endlink bolt back into the lower control arm and put the nut back on.
Old Sep 9, 2012 | 05:56 PM
Ouija's Avatar
Alright, I lost the bolt though since it fell off while driving. I'll try to find one at Pepboys or something..the only thing is I don't know if I stripped the bolt or the nut. I'll find out soon though.
Old Sep 9, 2012 | 06:04 PM
Ouija's Avatar
it's part number 14 in this picture if anyone's interested (directly in the middle of the picture) -
Old Sep 9, 2012 | 06:41 PM
herrschaft's Avatar
You'll be fine with normal driving. One of mine has been disconnected for over a month now.
Old Sep 9, 2012 | 09:31 PM
Ouija's Avatar
Oh wow, alright, yeah I'll get another bolt soon and put it in.
Old Sep 10, 2012 | 01:30 AM
Tolboothwilley™'s Avatar
you might need to buy a replacement for it if the threads are screwed up - its like $20 per endlink.
Old Sep 10, 2012 | 08:22 AM
Ouija's Avatar
Yeah if the new bolt doesn't go in then I will have to, Infiniti quoted me $53 for a new one -_-
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
vamarris
Sep 26, 2015 12:56 PM
