Problem with the toe in the rear..
Old Oct 19, 2012 | 05:42 PM
Wisco-G35X's Avatar
G35
Originally Posted by JaE35
I already know the problem behind most of these alignment threads before i even read them lol...the guy doing the alignment is an idiot..of course adjusting the camber effects the toe
I understand that but shouldnt that effect on both side? because the right side is within spec. so my guess is something on the left side is bent.
Old Oct 19, 2012 | 06:00 PM
Shanes_G's Avatar
The right side sits higher on all G's naturally
Old Oct 19, 2012 | 06:02 PM
Wisco-G35X's Avatar
G35
I didnt know that. Well guess we'll find out tmrw. Gonna install toe bolts and take it to an alignment shop
Old Oct 19, 2012 | 08:23 PM
lotteman's Avatar
I have a feeling ride height wasnt set properly or was set to account for driver weight. That would explain why the one side can't get back into spec.
What kind of coilovers do you have? are they true type or oem type in the rear?
Old Oct 20, 2012 | 03:05 PM
Xet's Avatar
Xet
Make sure the toe bolt holes are elongated to the specs of the provided guide bracket
Old Oct 22, 2012 | 10:11 PM
Wisco-G35X's Avatar
G35
Megan coilovers not the true type.
Old Oct 23, 2012 | 06:04 PM
Wisco-G35X's Avatar
G35
Also I'd hit a manhole couple days before I install coilovers and rims. I did hit it pretty hard cuz i heard the loud bang. So after I installed coilovers and rims and already had that toe out in the left rear. I found another problem. Im gonna put the car on the lift tmrw and look through everything see what need to be replace.
Whats u guys thought on what could be damage other than that bent motor mount?
Attached Thumbnails Problem with the toe in the rear..-img_1750.jpg   Problem with the toe in the rear..-img_1751.jpg
Thebaws11
Jul 2, 2021 11:36 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
jbmw002
Sep 10, 2015 12:54 AM
