Problem with the toe in the rear..
Old Oct 14, 2012 | 12:47 PM
Wisco-G35X's Avatar
G35
Unhappy Problem with the toe in the rear..
Hi, everyone. I took my car to an alignment shop yesterday (Car has Megan coilover) and the guy called me and he said theres a problem. On the right side everything is fine, camber is setting at -3.5*. But on the left if he try to give more negative camber the toe will start to turn out. So basically the more negative camber = toe keep turning out.
Ive search but couldnt find anyone with similar problem. I was thinking may be the toe arm was bent.
Any help would appreciate it.
Old Oct 14, 2012 | 12:52 PM
Shanes_G's Avatar
Do you have toe bolts
Old Oct 14, 2012 | 02:11 PM
Wisco-G35X's Avatar
G35
No, I don't have toe bolt as of right now.
Old Oct 14, 2012 | 02:14 PM
Shanes_G's Avatar
You need toe bolts to get within specs with that amount of camber
Old Oct 14, 2012 | 02:21 PM
Wisco-G35X's Avatar
G35
Ok. But the right toe sit perfect though with that much camber just the left that out of whack. But I'll get the toe bolt anyway since I don't have them yet.
Old Oct 14, 2012 | 02:25 PM
bluedevils95's Avatar
I hope you get your toe bots soon. Did you buy them already? I do have a set for sale just incase you didnt order it.
Shanes_G's Avatar
I'm surprised that your toe is even In specs on the right side. You have camber arms?
Old Oct 14, 2012 | 02:27 PM
Shanes_G's Avatar
What year is your car?
Old Oct 14, 2012 | 02:42 PM
Wisco-G35X's Avatar
G35
Yes, I have SPL rear camber arm and my car is 04.
Old Oct 14, 2012 | 02:43 PM
Xet's Avatar
Xet
Are you running aftermarket arms? If you are dropped a substantial amount on those coils you will need a camber kit along with extended toe bolts as well as to elongate the holes for the toe bolts
Old Oct 14, 2012 | 03:40 PM
Wisco-G35X's Avatar
G35
Lets hope this toe bolts could bring it back to spec.
Old Oct 16, 2012 | 05:44 PM
Wisco-G35X's Avatar
G35
Could it be 'cause something was bent such lower control arm?
Old Oct 16, 2012 | 06:29 PM
P10 WRC's Avatar
of course toe will change as camber changes. Toe is adjustable just like camber.
Old Oct 19, 2012 | 05:25 PM
Wisco-G35X's Avatar
G35
Toe bolts came in yesterday. If that dont fix the problem, i guess my next stop would be replace rear uca and lca (the one that hold the spring).
Old Oct 19, 2012 | 05:31 PM
JaE35's Avatar
Moderator
G35 Sedan
I already know the problem behind most of these alignment threads before i even read them lol...the guy doing the alignment is an idiot..of course adjusting the camber effects the toe
