knocking/creaking sound in front suspension.
Old Nov 24, 2012 | 11:47 PM
osuav8r's Avatar
What you're describing sounds to me like maybe your sway bar end links or the bushings that attach them are shot. They're really cheap to fix and primarily make their problems known at low speeds on speed bumps. It should be obvious if they need replacing once you look at them. They're probably the easiest bushings to change so I'd check them first. Good Luck!
derres
Aug 28, 2015 03:27 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kinetek
Aug 3, 2015 04:25 PM
rping
Jul 26, 2015 09:53 PM
