General suspension q&a
Old Nov 13, 2012 | 10:51 PM
Kng35's Avatar
Ok let me start by saying I'm completely new to owning a car. I've always owned trucks. Lowered and 4x4. But I decided a year ago I wanted a nice car. So I bought a 04 35 coupe. The guy before me lowered it and I believe all he did was put new lowering coil overs on it, never corrected the negative camber. I've always worked on my own vehicles and Ive got a lot of knowledge on vehicles but something I've never done/learned is camber and toe alignment etc. I wanna fix the negative camber my car has but not 100% sure how to or what parts are good being that all the trucks I've lowered we're easy and don't really have camber issues with big rims. I just need general help/direction on how to go about fixing my car so it rides better and get more life out of my tires. Any advise can help. Thank
Old Nov 13, 2012 | 10:56 PM
faiz23's Avatar
Old Nov 14, 2012 | 01:07 PM
VMRWheels's Avatar
^+1
SPL makes good stuff.
Old Nov 15, 2012 | 09:00 AM
Kng35's Avatar
Originally Posted by VMRWheels
^+1
What about spc products? Are they any good? Another question is how do I find out how low my car really is. Like how much it's lowered?
Old Nov 15, 2012 | 02:27 PM
OBsessed's Avatar
Nothing wrong with SPC parts, they tend to be a little less expensive than the SPL stuff but they're fine. I have a mix of SPC and SPL parts on my car, and at some point I'll get around to upgrading the SPC stuff, but there's been no problems with any of it. The SPL stuff is just incredibly beefy and awesome.
You should get your car on an alignment rack if you haven't already done so to figure out a) how far (if at all) out of spec you are, and b) if you even need to buy anything aftermarket to correct it. It may just need a toe adjustment depending on how low the car is. The G35 coupes run natural negative camber in the -1 to -1.5 degree range if I remember right and camber won't really destroy your tires, toe will. It may cause slightly uneven wear over a long enough period of time, but this is usually minimal if your toe is in spec.
Also for measuring how low you are, compare your fender measurements to the list below:
Grab a tape measure and measure from the ground to the center of the wheel arch and compare to:
From the Factory Service Manual (ie FSM)
Wheelarch Height (Unladen = full tank of gas, spare tire, jack etc in stock locations)
With 17"
Front: 691 mm (27.20 in)
Rear: 702 mm (27.64 in)
With 18"
Front: 694 mm (27.32 in)
Rear: 710 mm (27.95 in)
With 19"
Front: 699 mm (27.52 in)
These measurements are from the ground to the high point of the arch (centered on the wheel hub).
Old Nov 15, 2012 | 05:39 PM
VMRWheels's Avatar
SPC products are fine. If you're wondering about how low you are though you should measure your fender to ground height.
Old Nov 19, 2012 | 11:06 AM
Kng35's Avatar
Alright so over my weekend I did the measurements and I didn't think about air pressure in my tires,So forgetting about the tires all being at the proper air pressure none of them had the same height I had 3 tires all just over 25 in and one just under 25. Sat at 24 5/8.. So its safe to say it has about 2" in drop also I didn't know if it made a difference but I also have 1" wheel spacers on the car
Old Nov 19, 2012 | 12:59 PM
OBsessed's Avatar
So your next step would be to take it to an alignment shop (for a check-up, any place will do) and see what your current specs are at. If the shop can get your toe back in spec as is let them, if not you'll know you need to look into an aftermarket kit to correct toe (and camber if you want but base that decision on the results of an alignment machine, imo). You'll be amazed how much of a difference correct toe makes in the ride quality if it's bad right now. I know you originally mentioned camber and I'm intentionally not focusing on that. If you want to keep your tires toe is your first priority.
Post up the results of the alignment machine too if you want a hand. I'm pretty sure the factory / OEM recommended specs are in a sticky post around here somewhere too.
Old Nov 19, 2012 | 08:16 PM
Kng35's Avatar
Alright sounds good. I'll try to get it in a shop this week. I'll definitely post the results if I can. It does ride a lil rough now. Reminds me of being in a truck almost lol thanks to everybody with there info and input
Old Nov 25, 2012 | 05:46 PM
Kng35's Avatar
I had the car at the shop Friday. Got the print out but I don't know how to post it online. The car rides better and smoother but guy at shop said it would need a kit for front and rear to be better. Anyone know how to upload pics to this site?
Old Nov 26, 2012 | 07:27 PM
OBsessed's Avatar
You'll need some place to host them like Photobucket or something similar. Then you can use the [img] tags to share it here.
Old Nov 26, 2012 | 11:27 PM
Kng35's Avatar
[/IMG]
Old Nov 26, 2012 | 11:33 PM
Kng35's Avatar
Okay so I have tried several times to get the picture to upload. For some reason I can't get it to work thru photobucket. If any of you wanna see it I'll definitely send you a email with the picture. Just email me at kellyneighoff@gmail.com thanks
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
