View Poll Results: Which one ?
Tokico D-Specs
40.00%
Tokico Blue
50.00%
Bisltein HD Struts
0%
Other Struts
10.00%
Voters: 10. You may not vote on this poll
Tokico D-Specs / Blue - REVIEWS?
Old Dec 14, 2012 | 12:47 PM
terrorx7's Avatar
Originally Posted by gary c
I've been running Tein 350Z H-Techs with Tokico D Specs for 6 months....love em!
Gary
I just purchased the exact same set up. Is the ride comparable to stock sport suspension? I'd imagine with adjustable damping you could set it how you want...how do you have yours?
Old Dec 14, 2012 | 12:55 PM
nova15566's Avatar
I have run both on my g35. I love the dspecs for daily driving and the occasional drift/track day. I also have coils but choose to run the dspecs basically 100% of the time.
If paired with the right spring setup they will handle great... I have solid bushings as well as sways on 350z springs (not sure which ones are on the car at the moment (i have a few). If you want to be lowish I would suggest buying the 350z version (slightly shorter) on 350z lowering springs (that is what my car is on).
Old Dec 16, 2012 | 02:01 PM
jutn35's Avatar
G35 Coupe
iono just to be safe im going to go with G35 Tein Htechs and G35 tokicos
Old Dec 16, 2012 | 04:13 PM
ItsA..Gthing's Avatar
^^^I got the g35 H-techs...and 350z tokicos....the Z shocks supposed to rebound better on turns...probably
a good balance for the soft Tein g35 springs...
Old Dec 16, 2012 | 04:15 PM
jutn35's Avatar
G35 Coupe
OOH is that why, and there is no re-fabrication and its all perfect fitment . plug and play? ^
Old Dec 16, 2012 | 05:07 PM
Yes...plug in play....the G and Z parts are interchangeable..
Old Dec 16, 2012 | 05:24 PM
jutn35's Avatar
G35 Coupe
ok, so ill get better handing with the Z spec tokico blues. but also maintain close to stock height ?
Old Dec 16, 2012 | 05:30 PM
Yes...the springs u get determine the height.....Z H-techs are half an inch lower drop then G h-tech springs...
Old Dec 18, 2012 | 11:18 AM
G35fromPA's Avatar
Originally Posted by jutn35
i hope it was just bad luck for that case, but i just hate to have adjustments i would never use, or if i have to adjust itll be a pain to do so for the rear, the fronts i can imagine are easy since they are exposed in the engine bay.
Yes, I think it was bad luck. I don't adjust them often, but I do soften them a bit for the winter driving (read: pothole) season, and I have the extensions in the rear so it's not a big deal to adjust them. I just like being able to tune them to my personal handling/ride preference and then leave them that way. And stock ride height was my goal also.
Old Dec 21, 2012 | 10:35 PM
OK ..Op ..Finally installed the G35 Tein H-Techs/350z tokico HP blues.....The ride is great. Nice combo IMO. Glad I opted for the 350Z blues....Get them, u will feel like stock with better handling. Alignment is in the green with 1 degree of camber in front and 2 degrees in the rear...Toe zeroed out.....
Old Dec 22, 2012 | 12:11 AM
totopo's Avatar
hey everyone, we have shocks all around, not struts. kthxla~~~
http://en.wikipedia.org/wiki/Strut#Automobiles
Old Jan 5, 2013 | 11:14 PM
jutn35's Avatar
G35 Coupe
Will the Tokico Blue HP come with dust boots or will i need to order some from Nissan ?
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
