what is wrong with my suspension
Old Dec 27, 2012 | 10:34 PM
DaGdriver's Avatar
Im on stock suspension and only one centimeter of the inner tire gets eaten up the most. any ideas. I got alignment done about 3 months ago.
Old Dec 27, 2012 | 10:37 PM
lotteman's Avatar
you have a lot of negative camber with a good about of toe. Either you're lowered and dont have the neccesary suspension parts to get it back within spec or the alignment tech didnt tighten them enough.
Old Dec 27, 2012 | 10:42 PM
hurleyguys's Avatar
if ur positive ur on stock suspension your got a bad alignment.
Old Dec 27, 2012 | 10:43 PM
Plur's Avatar
Camber kits installed before alignment?
Old Dec 27, 2012 | 11:06 PM
DaGdriver's Avatar
No i dont have a camber kit and i am definitely on stock suspension. I just got stock shocks and springs. I also have the OEM rims. I go through tires like crazy and get an alignment done every time i get new tires from firestone cause i bought the unlimited alignment package.
Old Dec 27, 2012 | 11:09 PM
Plur's Avatar
Flip your tires and go to another firestone location. Your previous alignment must have been wack.
Old Dec 27, 2012 | 11:11 PM
Big Booty Trudy's Avatar
I see what the problem is.. You went to Firestone.
Old Dec 27, 2012 | 11:14 PM
DaGdriver's Avatar
alright man ill do that for sure. but u see what im talking about right? all the wear just in the very inner centimeter (that dip)
Old Dec 27, 2012 | 11:15 PM
DaGdriver's Avatar
hahaha is firestone that bad? i didnt know that..
Old Dec 27, 2012 | 11:17 PM
I've had terrible experiences with them. Do not recommend at all.
Old Dec 28, 2012 | 03:34 AM
The Stimulation's Avatar
I'm surprised nobody has mentioned that it could be your bushings. They may be worn out and thus throwing off your alignment and will continue to do so. If you haven't had them check out, check it out, especially the lower control arm bushing.
Old Dec 28, 2012 | 03:56 AM
lotteman's Avatar
^he's absolutely right. Worse case scenario is that something is bent.
Old Dec 28, 2012 | 10:30 AM
6mtg's Avatar
I've had to take my g back to the same firestone 3 times to get it right I picked it up drove about 3 minutes and turned right around and went back the one near me is full of idiots, but could be a few things I would jack the car up grab the top and bottom of tire and try and wiggle it to see if there is any play in the suspension
Old Dec 28, 2012 | 12:12 PM
DaGdriver's Avatar
Dang I got my lower control arm changed out last year.. Could be a busted ball joint? Like my ball joint is is leaking.. And my car kinda leans to the left if I closely look at it from a distance.
Old Dec 28, 2012 | 12:13 PM
DaGdriver's Avatar
Dang man that's a horrible experience at Firestone.. The one go to is pretty cool but then again idk if they did my alighnmeant right haha
