Swapping Brembo Brakes with Standard Brakes
Old Feb 15, 2013 | 02:58 AM
Rob Treleaven's Avatar
I have an '03 G35 Coupe - manual transmission with Brembo brakes
and an '04 G35 Coupe - automatic transmission with standard brakes.
Should I decide to sell the '03, I may want to put the Brembos on the '04.
If anyone has had the ACTUAL EXPERIENCE of fitting Brembos to a standard brake G35 or vice-versa, I would be very interested in any comments you may have. I suspect fitting them may be fairly straightforward, however the computer and sensor systems of the vehicle may complicate things.
Thank you
RT
Old Feb 15, 2013 | 03:33 AM
RCL's Avatar
RCL
I did the swap, stock to brembo, piece of cake. No complications at all. Take brakes off, put new ones one. That simple. Make sure to swap the brembo lines too though. Stock lines and banjo bolt will not work with brembos, but you have everything you need.
Old Feb 19, 2013 | 03:06 PM
G35fromPA's Avatar
Brake boosters and master cylinder diameters are different on the two cars so pedal feel and effort won't be exactly the same.
Old Feb 19, 2013 | 06:40 PM
Frankieg35's Avatar
U need the rear bolts from the brembos..
Old Feb 19, 2013 | 06:58 PM
JaE35's Avatar
Moderator
G35 Sedan
everything you need is here, you don't need to swap the master cylinder either
http://my350z.com/forum/brakes-and-s...bo-brakes.html
Old Feb 19, 2013 | 10:09 PM
Thank you so very much for this great source of information. This is tremendously helpful and I really appreciate you taking the time to help me out here!
Cheers
Rob Treleaven Burlington Ontario Canada
Old Feb 25, 2013 | 03:01 PM
G35fromPA's Avatar
No, you don't need to, but it's a good idea. It affects pedal travel, effort and feel.
Old Feb 26, 2013 | 09:24 AM
Thanks very much for this. I think this is good advice as well and it makes sense to swap out the whole system to be certain to retain the "feel" and full character and performance as you indicate. I will add this to the "to do" list for when I do this project.
Cheers
Rob
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Joe Gargano
Sep 18, 2015 11:17 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
