Small Questions Thread: Brakes and Suspension
You'll likely need at least rear camber kit with toe bolts. Go with SPC or SPL brand and make sure it includes the elongated toe bolts. SPC is probably around $140ish I'd guess, SPL is more.
You also may need a front camber kit to get fully back in spec, but again going with SPC or SPL is at least a few hundred bucks. For fronts it may pay off to get it aligned first and then see how close they can get it to spec before buying the front kit since it's so much more expensive. Make sure they get toe in spec and then match camber as close to spec as possible.
I was taking off my non adjustable endlinks from the front Hotchkis sway bar and the nuts are seized. They are so hard, even using wd40 and a longer pipe for leverage, it won't budge. I got the front passenger bottom nut off, but the top nut will not come off, you can't use anything like an allen head to hold and go the opposite way. The driver said is completely stuck, top and bottom, even with use of the allen head on bottom bolt.
Any advice especially for the top nuts that all you can use is a wrench?
I am looking at buying the 350z s or h techs and spring mount mod for my coupe. If I am running wheels that are poking a small amount, and I like the look of the extra camber camber induced by the drop, would the camber kits be necessary? Simply do camber kits only allow for excessive adjustment to camber to return to the OE specs or do they also allow the toe to be adjusted the necessary amount?
Wheel spoke design has more to do with BBK clearance than offset alone. Some offer a template that you can cut out and use to determine if your wheels will clear.
Camber kits give you adjustability. If you are okay with the drop induced camber, an alignment shop can get both sides even by using the eccentric bolts. As far as toe goes, you can buy aftermarket bolts to get your toe back to spec. Remember, Toe kills tires 20x more than camber does. Install the springs and then wait a week or two for them to settle. You should look into swift springs as they are miles ahead of the competition.
They are the lightest springs you can buy, which helps a lot. The other thing is they are designed around the OEM strut and are also true to rate. I went from eibach to swift and the difference was unbelievable. They are also linear and not progressive like the Teins.
#30
