Alignment Specs after SPC Camber Kit
Old May 15, 2013 | 04:41 PM
lcysimon's Avatar
Do these worn LCA / UCA bushings cause the car to ride like crap and creat annoying squeeking metal sound?
I am at 98k and my car rides horrible even with new struts and shocks.
Old Jun 18, 2013 | 12:06 AM
ItsA..Gthing's Avatar
Im sure you drove that supra pretty hard..lol 2 degrees of negative on the rear wont kill your tires as long as your Toe is zeroed put...
Old Jun 18, 2013 | 09:58 AM
LoSt180's Avatar
Did you install the shims that came with the front arms? It bolts up to the wheel hubs. I didn't use those at first, after install I was able to get my front from -0.8 to -0.1 camber. Also, verify you assembled the front caster/camber adjustment cam correctly.
Rear, I didn't even use the toe bolts and got the rear from -2.1 to -1.7. Recently had the rear tires flipped to help with camber wear since I mostly drive highway.
This is with a 20x9 front / 20x10.5 rear wheel setup.
paolojericho11
Sep 11, 2015 07:08 AM
Dundermuffin666
Aug 14, 2015 04:01 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
