Ok , i was riding on 350z htechs, and this weekend i got on stillen sway bars , front and rear, plus rear camber kit......noticed the car raised a bit then it was in the front and rear , my question, does my suspension has to resettle again or does it has to do with the sway bar kit
thegreatkwijibo
close
- Join DateAug 2012
- LocationHighland, Texas
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:142 Times in 123 Posts
Are you noticing more wheel gap, or that your bumper is higher off the ground? if its the latter its probably because you corrected the negative camber created by lowering it.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Quote:
When you noticed the difference was it right after you installed the sways? Sway bars have nothing to do with alignment FYI! Drive your car a few blocks it will settle back to it's previous height. Enjoy the ride and get SPL a-arms for the front so you don't waste your tires....GaryOriginally Posted by EuroG
Quote:
Yes im noticing a bigger wheel gap...., so thats the only thing i could think of what u said about the camber correcting the negative, which made me think that everything had to resettle once againOriginally Posted by thegreatkwijibo
Quote:
Yes, right after the install, just hopeing it will go back to its previous hieght ..it was perfect, but the car rides and corners great now , i just hope i wont end up needing the stechsOriginally Posted by gary c
Sways definitely have no effect, your camber would have to be really different to make much of a noticeable difference... Get it aligned and see how you like it, but it sounds like you may need to change your setup
Quote:
Yea...i was in positive front and rear....i had to get it back to negative , thanksOriginally Posted by Xet
