Squeak From Rear
Squeak From Rear
Hi all,
I have an 04 G35 coupe and the rear suspension is making squeaking sounds when I go over a bump.
The sound started a few weeks ago and I am wondering what it is...I have hotchkiss sway bars so I thought it might be my end links. Can anyone confirm what end links sound like when they are about to go?
I thought it might also be a bushing...diff? rear subframe?
I'm considering just buying a whole new bushing kit for my suspension and having them all replaced at once. If its the endlinks, I will buy power grid end links and call it a day.
Any Ideas on what to do?
Thanks
Thanks
It could be the bushings. I replaced all the bushings in my Galant and NOW I have squeaking...so even with the kit you may end up with squeaking. I replaced them several years ago and they may just be in need of some lubrication. I got the graphite infused from energy. But squeaking from what I have found anyway, is usually bushings being worn out
