Compression rod busing .. REPLACE OR LUBRICATE
Old Jul 1, 2013 | 08:59 PM
grigortheboss's Avatar
Recently I've had squeaky noises from my car when I make a right turn or left at slow speeds , and I've researched and found out its the bushings . Should I replace the bushingsSome dealers say u need to replace the whole rod. Some people say it just needs some silicone spray ? Really need help. It's not loud also very silent . Also is it an emergency I currently don't have much money so If its not gonna harm the car it can wait
Old Jul 2, 2013 | 12:15 AM
Blue Dream's Avatar
I drove ttrank's car solo
First off you bought the wrong car if you don't have money for even small repairs. However compression rod bushings generally don't squeak, the just fail and then you have a knocking/popping noise fron the metal arm of the rod grinding against the underbody of the car. Your more likely having an issue with your shocks or potentially the sway bar bushings which will squeak when the wear out the grease they are installed with. That's an easy fix if you're a DIY type of person, just have to take off the brackets the sway bushings fit in, re-grease, and re-install. Good luck with the fix.
Old Jul 2, 2013 | 12:25 AM
Don't have much currently *. And thanks, cuz I did some research and everyone that seems to have this problem says its the rod bushings so I'm confused
Old Jul 2, 2013 | 12:12 PM
DEMoLITIoN's Avatar
use this next time
https://g35driver.com/forums/brakes-...uspension.html
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
