BBK Myths
Old Aug 25, 2013 | 07:05 PM
WhosUrBuddiee's Avatar
BBK Myths
I have seen younger and younger people joining the G35 community and often believe several fundamentally incorrect principles about their cars. One of the biggest being the belief that Big Brake Kits actually decrease stopping distance. It should be clear to everyone that BBKs do not decrease your stopping distance at all. The actual purpose of BBKs is to dissipate heat (and improve visual appearance).
There are a few basic facts that must always be kept in mind when discussing brake systems:
1) First and most importantly. The brakes don't stop the vehicle - the tires do. The brakes slow the rotation of the wheels and tires. This means that braking distance measured on a single stop from a highway legal speed or higher is almost totally dependent upon the stopping ability of the tires in use - which, in the case of aftermarket modification, may or may not be the ones originally fitted to the car by the OE manufacturer.
2) The brakes function by converting the kinetic energy of the car into thermal energy during deceleration - producing heat, lots of heat - which must then be transferred into the surroundings and into the air stream.
The amount of heat produced in context with a brake system needs to be considered with reference to time meaning rate of work done or power. Looking at only one side of a front brake assembly, the rate of work done by stopping a 3500-pound car traveling at 100 Mph in eight seconds is 30,600 calories/sec or 437,100 BTU/hr or is equivalent to 128 kW or 172 Hp. The disc dissipates approximately 80% of this energy.
3) Repeated hard stops require both effective heat transfer and adequate thermal storage capacity within the disc. The more disc surface area per unit mass and the greater and more efficient the mass flow of air over and through the disc, the faster the heat will be dissipated and the more efficient the entire system will be. At the same time, the brake discs must have enough thermal storage capacity to prevent distortion and/or cracking from thermal stress until the heat can be dissipated. This is not particularly important in a single stop but it is crucial in the case of repeated stops from high speed - whether racing, touring or towing.
4) Control and balance are just as important as ultimate stopping power. The objective of the braking system is to utilize the tractive capacity of all of the tires to the maximum practical extent without locking a tire. In order to achieve this, the braking force between the front and rear tires must be nearly optimally proportioned even with ABS equipped vehicles. At the same time, the required pedal pressure, pedal travel and pedal firmness must allow efficient modulation by the driver.
5) Braking performance is about more than just you brake size. In order for even the best braking systems to function effectively, tires, suspension and driving techniques must be optimized.
All modern cars are equipped with Antilock Braking Systems. ABS is an electro-mechanical control system designed to monitor and influence wheel dynamics, and ultimately vehicle dynamics during braking maneuvers. In order of priority, these systems are intended to enhance vehicle 1) stability, or the prevention of oversteer 2) steerability, or the prevention of understeer and 3) stopping distance. Typical systems consist of 3-4 wheel speed sensors, an ECU containing the algorithm processing the wheel speed information, a series of solenoid-driven valves, and a pump-motor subsystem which can be actuated to interrupt and release brake fluid pressure from the wheel-end brake components (calipers and such).
To summarize, for two cars with the same weight, tires, and brake pad coefficient of friction - the stopping distances will be the same, regardless of how big the rotors are or how many pistons you have. BBKs are only to dissipate heat and reduce brake fade under repeated braking conditions.
If you want to improve your stopping distance, get better tires.
If you want to reduce brake fade, get better pads.
If you want to prevent vapor lock, get better brake fluid and lines.
If you want to improve visual appearance of your car, get a BBK.
Old Aug 25, 2013 | 08:26 PM
socketz67's Avatar
For example...
2004 G35 Sedan: Braking, 70-0 mph: 153 ft (Source)
2009 G37 Sedan: Braking, 70–0 mph: 160 ft (Source)
However, on long twisty roads or a track, the much larger/multi-piston caliper brakes on the 2009 would probably experience less fade and better modulation. They also look cool ;-)
Old Aug 25, 2013 | 09:07 PM
herrschaft's Avatar
Originally Posted by socketz67
For example...
Keep in mind the weight difference between the two. The G37 is over 150lbs heavier.
Old Aug 25, 2013 | 09:51 PM
socketz67's Avatar
I thought about that, but 150lbs is the size of a small man. Would that really make a noticeable difference in braking? Not trying to argue, but I myself is somewhat amazed that the huge Akebono brakes on the G37S are really no better performing in a real world test (70-0) than the brakes on the 1st Gen which were the source of law suits for Infiniti.
Old Aug 25, 2013 | 09:59 PM
Texasscout's Avatar
well said! BBK are mostly for looks, if you want track performance you need to go with a quick change system, so you can change the pads in a couple of minutes. For most of us, the stock brakes are more than adequate for street use.
Old Aug 25, 2013 | 10:01 PM
herrschaft's Avatar
Its closer to around 180lbs but I would think thats a significant difference in a comparison such as this. Like the OP said though, it all comes down to pads and tires. I'm curious if the brake booster/master cylinder were upgraded on the G37 to apply more pressure.
Old Aug 26, 2013 | 08:19 AM
Cux350z's Avatar
So would you agree you would experience fade in a single 200-0 stop? If a BBK would experience less FADE would it not stop the car sooner than an OEM set up?
Your article cannot have it both ways.If fade exists then a BBK can stop a car sooner compared to the puny OEM rotors on the 03 models.
Also a single 120-0 stop has 4x the energy as a 60-0 stop. So essentially 4x 60-0 stops ( where fade would occur??) vs 1 120-0 stop...which car stops sooner?
Old Aug 26, 2013 | 09:17 AM
Texasscout's Avatar
It doesn't matter...
The stopping power of ONE stop is related DIRECTLY to the contact patch on the pavement, and the stickiness of the rubber compound. ANY brake will make one stop from high speed. It's the number of stops that it can make before the fluid boils in the pistons. (Heat dissipation)
Old Aug 26, 2013 | 09:20 AM
Jairen's Avatar
Nice write-up!
As noted, I sincerely believe 99% of G owners who have BBK's do not need it. It's merely a cosmetic upgrade. In fact, I know Z owners who frequent the Nurburgring on OEM brakes and do just fine.
Old Aug 26, 2013 | 09:46 AM
Take a second to read what you wrote. When would you ever do a 200-0 stop in a G35 or 4 120-0 stops? Be realistic here.
Old Aug 26, 2013 | 09:50 AM
Sadly I have seen many people on here claim they replaced their stock brakes with some StopTechs and incorrectly claim to have much more stopping power. They fail to realize it is because of the new pads and has nothing to do with the larger calipers. They even try to use some failed juvenile attempt at Pascals law to justify their purchase.
Truth be told the additional unsprung mass of larger wheels and larger rotors will acually make stopping distance slightly worse.
Old Aug 26, 2013 | 09:54 AM
gary c's Avatar
Nice thread WhoUrBuddiee! Unless you're building a show car or find a deal you can't pass up, BBK is a real waste of your $$. To improve first gen braking all that's required are better pads and rotors! I'm using Hawks HPS pads and DBA rotors, works for me....Gary
Old Aug 26, 2013 | 09:55 AM
Originally Posted by Jairen
Nice write-up!
Changing out brake line to SS braided and changing brake fluid to one with a higher boiling point (like Motul RBF) will make a huge difference in brake fade. It is more than enough for an average track driver. Plus tires, pads, light weight wheels will make more of a braking improvement than even the most expensive BBK.
I would be confident in saying 95% of people on here with BBKs did not need them from a performance standpoint.
But they do look sexy. I am not against mods for looks.
Old Aug 26, 2013 | 10:25 AM
socketz67's Avatar
NASCAR? Laguna Seca?
The 70-0 tends to be my personal benchmark for any car since that's the average speed people drive on the highway here in Socal.
Old Aug 26, 2013 | 10:32 AM
Th3R3dStar323's Avatar
stock brembos ftw
