Caliper
Old Nov 24, 2013 | 12:15 AM
clearheart's Avatar
Caliper
Ok I didn't wanna make a thread about this due to there being a question thread for FAQ but couldn't find my post thus resulting in this because I need an answer. I have a 04 G35 coupe with brembos'. I ended up stripping the passenger caliper trying to reinstall by brake setup.
https://g35driver.com/forums/g35-cou...ripped+caliper
The link above is all i could find on this matter, yet i need to know what heli coil kit to purchase so i can redrill and tap my current brembo and fix it.
Old Nov 24, 2013 | 03:18 PM
saywat?'s Avatar
the bolt size is 22mm. I just did my rotors. those bolts are tight!
Old Nov 24, 2013 | 09:51 PM
clearheart's Avatar
man who you tellin it took some force to break myne. thanks for the size i'll see what I can find as far as tap for my caliper. Really hoped to fynd someone who's also done the heli coil mod. I can't be the only one to strip the threads in the brembos. I was thinking akebeno but i'd rather work with the brembos
Old Nov 24, 2013 | 10:53 PM
saywat?'s Avatar
at first I thought I could do it by hand with a breaker bar but that didn't help. wasted lots of time energy till I got the idea online to use a jack lol. it was so easy after that . used jack on the driver side. for pass side I was able to use my full body weight and stand on top of the big wrench I used. my bolts came off nicely
Old Nov 27, 2013 | 12:37 AM
clearheart's Avatar
now when you say you used a jack what did you jack up? the knuckle?
Old Nov 27, 2013 | 12:45 AM
saywat?'s Avatar
I turned the rotor all the way to the side, put the 22mm large wrench into the bolt so its horizontal then pumped the jack upwards at the end of the wrench to crack the bolt loose
Old Nov 27, 2013 | 01:26 AM
gary c's Avatar
You should have learned a lesson, never let anyone install your wheels using a Impact Gun! Not only will they strip your lugs but they'll warp rotors by over tightning...Gary
Old Nov 27, 2013 | 01:29 PM
saywat?'s Avatar
^wtf? random gary strikes again lol
Old Dec 1, 2013 | 03:25 AM
clearheart's Avatar
thanks all, and to mr. gary I agree yet this was my first time changing the braking on this car since I just bought it. I was doing my inspections I always do a tune up when buying a used car cause I don't know what the last owner had done previously or if they used quality parts. I only use what's highly spoken of here on the forums. Most people that don't know about the forums for there vehicles tend to neglect them.
Old Dec 1, 2013 | 03:30 PM
saywat?'s Avatar
maybe I missed something here but wat does the 2 caliper bolts have to do with the random comment that gary posted and how was he helpful to ur cause?
Old Dec 1, 2013 | 09:32 PM
clearheart's Avatar
it may not be a direct relation but it is helpful advice non the less. random or not it's information that aids me in bettering my knowledge in tuning my car.
Old Dec 1, 2013 | 11:53 PM
saywat?'s Avatar
eh, id rather thanks those who contribute direct helpful info pertaining to the thread rather than random mumbo jumbo not related to a thread
Old Dec 2, 2013 | 09:25 PM
clearheart's Avatar
LOL understandable
seagrasser
May 3, 2022 09:43 AM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
NJ6MT
Sep 10, 2015 08:40 AM
