Question: What do I need to replace rotors?
Old Jan 14, 2014 | 12:57 AM
thenexthendrix's Avatar
At the moment I have a 2004 Infiniti G35 Coupe with Brembo brake package. Sadly, I now need to replace them but somebody said I may need new rotors? Do you have to replace your rotors everytime you replace brakes? Or only when the brakes are almost gone completely?
I found a brembo brake replacement already but cant seem to find just slotted rotors. They are all coming in kits with calipers, rotors, brake lines and everything. Do I need new brake lines if I buy new Rotors or replace my brakes?
Sorry for all the question, Im so lost
Old Jan 14, 2014 | 01:06 AM
BowWizzel's Avatar
To replace rotors you generally should get new pads. If just pads than get rotors resurfaced unless too worn out to get resurfaced.
Old Jan 14, 2014 | 01:13 AM
thanks, any suggestions on good brands of slotted rotors? and are there special rotors for brembos? or wheel size?
Old Jan 14, 2014 | 01:15 AM
thegreatkwijibo's Avatar
unless the rotor is warped just measure how thick it is and make sure it is within the spec stamped onto the rotor if it is warped, you may be able to machine it and take care of it as long as it isn't too thin. If it is too thin, or warped beyond repair then you would need to replace them, and you should replace the pads with them. If they are ok just replace the pads if necessary and you are good to go.
Old Jan 14, 2014 | 01:25 AM
thank you, better to go cross drilled, slotted, or both with rotors?
Old Jan 14, 2014 | 10:20 AM
Gman56's Avatar
Are you going to do any track time with it? Centric make a nice rotor you can get whatever you want slotted-drilled or slotted and drilled. That what Im going with when I replace mine slotted and drilled with camfer on the holes.
Old Jan 14, 2014 | 10:35 AM
http://www.knsbrakes.com/c/car-item/...Slotted+Rotors
I ended up going with these because of the cheap price and location in the state i live in. Also, I got a set of Hawk HPs for 140
Old Feb 13, 2014 | 08:49 PM
MacTwidget's Avatar
04 Coupe w/Brembos
The local Infiniti dealer quoted me $1200 to replace my front rotors and pads.
OEM Brembo rotors are crap. It's their calipers that they are known for.
I went to RockAuto.com and got StopTech (Centric) drilled/slotted and StopTech pads for around $250.00 including shipping. So far I am VERY happy.
Question: What do I need to replace rotors?-img_1016.jpg
Question: What do I need to replace rotors?-img_1018.jpg
Question: What do I need to replace rotors?-img_1019.jpg
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
miata007
Aug 17, 2015 04:36 PM
RedBaronK
Jul 27, 2015 03:19 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
