Popping noise from front suspension.
Old Jan 21, 2014 | 03:24 PM
Invalid_User's Avatar
Has anyone had a popping sound come from the front when turning?
I replaced compression rod bushings and lower ball joints yet I still have this popping sound when turning the steering wheel. Sometimes I will hear the pop when coming to a hard stop.
Old Jan 21, 2014 | 03:30 PM
Urbanengineer's Avatar
I've recently acquired this one. Gdirtyfive told me there is a connecting rod between the front left and front right wheel that a nut becomes loose on. Tighten these down and the popping should go away.
My lift comes in this week and I'll test that theory. Pretty much what is happening is the rod is raising up on the bolt and torquing the whole rod. When it reaches a maximum it pops back into shape. Good luck!
Old Jan 21, 2014 | 07:25 PM
.cakestar's Avatar
i have this same issue. when you lift up your car do you think you can snap some pics to show the specific nut you are referring to? it pops when im slowly turning in either reverse or 1st.
Old Jan 21, 2014 | 07:33 PM
Its quite embarrassing when im reversing out of a parking spot and hear a big pop lol. Feels like I am driving some POS
Old Jan 21, 2014 | 09:02 PM
It might be a bit, but i've favorited this post and I will provide the clearest pictures possible using nikon as a medium. No crappy cell phone pics!
Old Jan 25, 2014 | 01:19 AM
Update:
So today I had some RHFCs being installed and decided to look for any loose bolts. While my car was on the lift I checked a nut on the driver side (since thats where the popping sound only came from was on the driver side) and I was amazed that it was loose that I could hand turn it. The bolt was located on the actual subframe near the tire. I will try and look for a diagram to show you what it looks like.
But so far no pops or noises reversing or stopping hard.
Old Jan 25, 2014 | 10:40 AM
My lift just came in.... I'll have it up by Sunday. Throw up some good pics!
Old Feb 11, 2014 | 12:20 PM
Thanks Urban for reminding me about this thread. I really wish I took pics, but after a couple days I noticed the sound coming back. since the beginning along with the popping sound was that sensation that something was loose every time I would come to a complete stop or go. which gave me the impression that something must be loose. of course I did find those loose nuts and bolts underneath but that's expected for a lowered car like mine. The tightening of the bolts helped but that sensation of something loose stayed. I I decided to replace my outer tie rods with Tein. The only reason I did the outers only because the shop had no inners in stock. After the install the sound completely disappeared, not only that but the whole front felt much stiffer. That loose sensation all but vanished, you would think that I just installed some TEIN mono flex damper.
Old Mar 2, 2014 | 01:35 PM
Thanks IU!
My bushings aren't cracked to destruction, but are having hairline cracks perpendicular to the mounting point. When is it time to replace?
Old May 21, 2014 | 12:51 AM
It's always good to replace most with whiteline bushings. As we allknow Nissan bushings are not thatgreat . The reason too go with workers white line is the metalcasing that prevents noise like creaking
Old Mar 26, 2019 | 10:51 AM
armstrec's Avatar
G35X
Popping noise resolved
I can twist one of my tie rods by hand. The other does not move. Is this causing the intermittent popping noise when turning?
Old Apr 12, 2020 | 03:46 PM
Slump God's Avatar
G35 Coupe
Hey Bro was the tie rods the issue?
Old Apr 12, 2020 | 04:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Basically all the moving parts in the front CAN make a popping noise, tie rod ends, wheel bearings, compression rod, both ball joints. You need to troubleshoot YOUR vehicle to see what's causing it.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
cyrus32
Jul 18, 2015 06:22 PM
papo020
Jul 17, 2015 10:30 PM
