Which coilovers and camber kits?
Old Feb 28, 2014 | 12:41 PM
g06driver's Avatar
in the market for some coils and camber kits...I've done a lot of research but can't decide. I want to be able to give it a slammed look but don't want to spend an arm and a leg. I don't care much for dampening as I do not track my car but it would be nice to have if the price allows it. I was thinking maybe BC coils but I have no idea for camber kits, just that I want to be able to run about -3 to -4 camber all around.
Any suggestions that will not break bank would be appreciated. Thanks guys.
Old Feb 28, 2014 | 12:59 PM
DEMoLITIoN's Avatar
You should check out PSM stuff.
$1000
Light weight and strength are combined in our many aluminum components
Full tap independent adjustments
Aggressive damping range with fast adjust
Allows you to do 32 clicks of damping change in just 12 clicks!
Pillow ball upper mount on front AND REAR!
Replaceable shock & customizable spring
FAMOUS Super low ride height ability
Billet T6061 lightweight aluminum Lower mount with urethane bushing
All aluminum components are hard anodized
High rigidity/High precision piston rod design exceeds racing standards
Full thread tap piston and locking collar allows vehicle height to be adjusted independent of the spring preload
2 collar wrenches are included
Light weight T6061 aluminum spring perch and locking collar designed to bear the weight of vehicle
Unique use of spring upper perch front and rear provides independance between the spring and the pillowball on all 4 corners
Linear spring available to special order in custom Kg (even numbers only)
$250
~ lifetime manufacturers defect warranty
~ All steel tubular construction
~ Teflon lined spherical bearings
~ Forged Clamping rod end receiver
~ Forged Clamping double threaded adjuster makes double sure your settings never come loose
~ Super long adjuster threads have the most thread overlap and more adjustability than anything on the market
~ Adjuster away from the subframe, on the knuckle side for easier adjustments
~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion
~ Laser cut reinforced mounting bracket
~ Copper and Gold plated finish
Old Feb 28, 2014 | 01:14 PM
g06driver's Avatar
cool i'll def consider...any testimonials?
Old Feb 28, 2014 | 03:50 PM
Frankieg35's Avatar
Stance and spc
zoop425
Mar 29, 2016 05:51 PM
kr33p
Steering & Suspension
Sep 7, 2015 11:23 PM
G4ORCE
Aug 22, 2015 01:16 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
