Need help with differential.
Old Mar 13, 2014 | 12:47 AM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by herrschaft
An open diff will turn the wheels in opposite directions when the car is jacked up. Another way to tell is by holding one half axle steady and turning the flange on the front, that one half axle will remain stationary while the other will turn.
A VLSD will spin both half shafts in the same direction no matter what you do.
what if I oped the diff. what visual differences between them?
Old Mar 13, 2014 | 08:09 AM
LoSt180's Avatar
Open diff will be able to see small gears in a cage easily. LSD is more of a sealed unit.
Open diff on left, LSD on right (LSD is an aftermarket unit, but you get the idea)
Old Mar 13, 2014 | 09:56 AM
JOKER's Avatar
CLUB MODERATOR
I thought so.
Well. let's see if the seller is willing to pull the back cover off.
Old Mar 14, 2014 | 01:40 AM
DrewDrew's Avatar
What version of the g37 did it come off of?
Base/Journey/X?
Old Mar 14, 2014 | 01:55 AM
JOKER's Avatar
CLUB MODERATOR
Journey
Old Mar 14, 2014 | 01:59 AM
DrewDrew's Avatar
Yea, forget I asked that...saw it on the last page. Derp.
I'll make it easy:
http://www.ebay.com/itm/2013-INFINIT...02afc7&vxp=mtr
Those 2 are direct bolt ups. g37s 6mt is 3.7 vlsd, also with the 4 bolt flange that directly bolts up to our cars. Only thing you need to do is take off the 2 abs sensor cables from those and bolt on the one that will stay on the car when you drop down the current broken diff.
Even if you get the diff you're currently talking about, youll have to swap the flanges from your current diff to the new one - all g37 auto diffs come with 3 bolt flanges that won't directly bolt to your current driveshaft. Save yourself time/money, grab one from a 6mt g37s.
trust me...I literally just got done installing mine an hour ago.
edit: forgot to mention the journey CAN come with vlsd, but only via a package option at time of purchase. you'd need paperwork from the car to find out I'm guessing.
Old Mar 14, 2014 | 02:32 AM
JOKER's Avatar
CLUB MODERATOR
do some tests on the fuel millage, let me know how it goes.
Old Mar 14, 2014 | 02:46 AM
DrewDrew's Avatar
I can give you average of my new mpg, but I never tested my mpg before. :/
Old Aug 25, 2014 | 08:11 PM
Speqz's Avatar
Joker, how did this turn out for you. Also what year is your g35?
Skilled
Drivetrain
48
May 11, 2020 09:09 PM
Marlin84
Apr 1, 2020 12:52 PM
Dannyy06
Sep 25, 2015 11:32 AM
Brwn5454
Drivetrain
Oct 30, 2010 11:49 PM
